VAG COM Changes - lap timer - AudiWorld Forums
A6 (C7 Platform) Discussion Discussion forum for the C7 Audi A6 produced from 2011
Old 07-27-2013, 06:53 PM   #1
jr'sAudiA6's Avatar
Default VAG COM Changes - lap timer
Verified that lap timer is enabled according the following:
[17 - Instruments][coding - 07]-> Long Coding Helper -> Byte 4
Bit 3 is checked. Latest VAG COM SW identifies this bit as the lap timer enable/disable bit.
I have not been able to find the lap timer under any of the DIS windows. Any ideas would be appreciated.
jr'sAudiA6 is offline   Reply With Quote
Old 07-27-2013, 07:06 PM   #2
Nyuni's Avatar
Make sure the DIC selection is on the "Red Tab", the trip computer/mileage/etc.
Hit the 'option' button on the steering wheel to bring up the mode changer, 'Lap Timer' should show up in the list. Scroll with scroll wheel and select.
Hope that makes sense, I didn't look up the 'proper' terms for these things in the manual. Interestingly enough, if you have the Innovation Package/HUD, selecting the Lap Timer will also bring up your currently selected gear and oil temperature on the HUD.
Nyuni is offline   Reply With Quote
Old 07-27-2013, 07:18 PM   #3
jr'sAudiA6's Avatar
I assume you are talking about the button that brings up a list such as On Board Computer, Efficiency program, Digital speedometer, Adaptive cruise control. If this is what you are referring to lap timer is not in the list. I have searched far and wide for an answer but to no avail.
Old 07-27-2013, 07:26 PM   #4
Nyuni's Avatar
Quote:
That is what I meant. Interesting... I've performed the same mod that you outline and I've got the lap timer. Mine's a 2013, though - perhaps there's some software difference between 2012 and 2013 that allows the timer to be activated?
Old 07-27-2013, 07:33 PM   #5
jr'sAudiA6's Avatar
So, anyone with a 2012 A6 have the lap timer enabled and been able to get it displayed? If so what did you do? And what version of MMI SW is installed?
Old 07-28-2013, 07:26 AM   #6
In 2012 models, the lap timer does not show up on the DIS, even though it can be enabled via Vagcom. I have the 487 version. I am likely getting an MMI upgrade next week (don't yet know to which version), so will try to see if it works after the upgrade.
dukeland is offline   Reply With Quote
Old 07-28-2013, 03:36 PM   #7
jr'sAudiA6's Avatar
Quote:
Thanks for the info, good to know that it isn't me, lol. Keep us informed as to what happens after your MMI update.
Old 07-28-2013, 04:01 PM   #8
Banned
Even if it shows you need to have a car with the driver assistance package that changes the turning signal selector.
feralc is offline   Reply With Quote
Old 07-29-2013, 09:11 AM   #9
jr'sAudiA6's Avatar
Quote:
Not sure I understand what you mean by your statement. I have the driver assistance package and yet the lap timer does not show in the list on the DIS. Does it work for your 2012 A7?
Old 07-29-2013, 11:46 AM   #10
Banned
sorry, what I meant is that even if it shows in your DIS (which in my case did not) you need the driver assistant selector on the left side to make it work, which I do not have either
http://www.audienthusiasts.com/Articles_LapTimer.html
Thread Thread Starter Forum Replies Last Post
October 25th Sunday - Touge.ca Shannonville Full track event 11:30-5:30pm #23 Event!! Touge.ca Canadian Discussion 1 10-18-2015 08:18 AM
Help with 2005 Audi A6-3.2L quattro BKH bballfreak A6 / S6 (C6 Platform) Discussion 4 10-12-2015 06:14 PM
Enabling comfort open/close from key on 2007 A8L iamdrewseph A8 / S8 (D3 Platform) Discussion 5 10-01-2015 12:33 PM
Disconnecting Mics on B&O system - Need Help! S6Express A6 (C7 Platform) Discussion 1 10-01-2015 05:30 AM
October 4th Sunday Cameron Kartways gokarting event 2:30-5pm,Touge.ca #24 Event 2015 Touge.ca Canadian Discussion 0 09-26-2015 12:30 PM
Tags
2012, a6, assistant, c7, enable, lap, night, temperature, timer, vag, vision
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
