VAG-COM (VCDS) coding for 2016 FL A6/A7
#51
Change the Adaptive Cruise Control Preset distance
Module 13 (distance regulation), adaptation, Channel 7 and change from 0 to 1. Reboot your MMI and you will then have an option in your MMI under Car, driver assistance and Adaptive Cruise Control to set which of the 4 distances your car will default to when you activate your ACC.
#52
Select the option "Distance basic setting option". Original should be Off. Change it to On. I'm assuming you're trying to get the setting to show up in the MMI. This should do it.
#53
#54
Hey thanks! I just compared our coding and it is identical....darn.
017501020000000013220002041A00102F0006E5F17001047E
Anyone who is more electronically inclined want to give me ideas on what to look for that the Kufatec changed so I can let everyone know?
Mike
Mike
This is my coding, and it is tottally different that yours; of course is an Audi A6 C7 Facelift 2016:
01750101FF0A000013110001000A00002F0006E5F1700100DF
#55
Has anyone figured out how to disable the phone and nav warnings while the car is moving? These are pretty annoying, and it seems that the module 5F adaptations are much different in the FL cars.
#56
Finally I got either the VIM and the Green Menu activated on my A6 FL 2016. It has been possible by the use of VCP PRO instead of VAG-COM.
More details at:
Activar Video en Movimiento (VIM) en nuevos A6 2016 (desde facelift Ma - Audi A6 / Allroad C7 (a partir de 2011) - Audisport Iberica
More details at:
#57
When I do this, I get "Request out of range" in VCDS.
I'm using VCDS 16.5.1 Beta with Hex-Net Interface with latest firmware.
Any ideas? I heard you needed a security code for this module (Code 14117) but it doesnt accept that either. At least not on my UK version of the Q7 4M!
My Module 13 is Part Number: 4M0 907 561 C
Yours starts: 4G....
Any thoughts would be appreciated
Andy
#58
Andy
I can't remember if I needed a security code, and I don't have one listed in my notes for that mod. But I do have 91153 in my notes for the "Starting off without driver trigger..." mod. Try that code. Not sure if it'll work. Ask the folks over on the Ross Tech forum if it doesn't work.
