VAG-COM (VCDS) coding for 2016 FL A6/A7
#21
So far its been more than 3 days and my trunk opening via key fob still works and so do the other mods!
#22
Hey guys...thanks. These are great! Got my Ross-Tech HEX-CAN+USB today and did several of these. Anyone know anything about getting rid of the amber corner lights when DRL's are running? Also, looking for coding on adjusting DRL LED levels...and anything else folks are locating.
#23
I was also able to change the speed at which the auto brights come on. This way they turn on even when you are going windy backroads....
Here is the code:
Go to module 20 (High Beam Assist), select adaptation, drop down menu select "High beam speed threshold", change to a speed of your choice. It is in KMPH and is about 60kmph as standard. I dropped mine to 25!
Here is the code:
#24
Traffic Sign Assist Activation
I found this coding at VCDSCODING.COM could somebody give me advice and tell me if I should try it in my 2016 A7? I'm in the US.
Thank You Very Much.
[Traffic Sign Assist Activation]
Select STG 5F (Information Electrical)
STG adjustment -> function 10
Select channel (63) vehicle function list BAP traffic_sign_recognition_0x21
Değer=Active
Select channel (151) vehicle menu operation-menu_display_road_sign_identification
Değer=Active
Select channel (153) vehicle menu operation-menu_display_road_sign_identification_over_thresho ld_high
Değer=Active
STG A5 (front / advance camera)
STG Access Permission -> Function 16
Access Code 20103
STG Long Coding -> Function 07
Byte 1
Bit 0 Activate - "01 Traffic Sign Recognition (FTE) active"
Select STG 17 (dash panel insert)
Byte 5
Bit 2 Aktivate
Select : channel numbers indicate end of speed limit
Importance to actively invest Show Valid suffix
View Channel Valid suffix
Corresponding value adjust default: 00100111
Değer=Active
Değer=Active
Değer=Active
Access Code 20103
Byte 1
Byte 5
Bit 2 Aktivate
#25
This has been tried before. Traffic sign recognition will not work in the U.S. Signs are all different and there is no database present for them.
#26
Thanks to everyone for posting these! I don't have a Vagcom, but may purchase one if there are enough mods for the 2016s.
#27
The coding is for Euro syle brake lights. Like it says - when emergency stopping, the brake lights will flash and the other option uses the brake lights when turn flashers are working. Legality could be questionable in U.S. locales.
Since the C7 TPMS system is passive/indirect and measures PSI differences between tires using ESP and tire rolling circumference to determine a low tire, it's not possible for the MMI to read out specific PSIs. There would have to be active tire stem sensors and special coding for measurement and MMI display - the C7 is not equipped with any of those.
#29
Hi all,
long time since posting on AW but I was wondering if anyone has been able to enable videos in motion or disable the engine start/stop feature? The VIM coding from older models won't work.
Thanks,
mike
Thanks,
mike
