VAG-COM (VCDS) coding for 2016 FL A6/A7
#62
To enable the menu that allows you to change the intervention time of the assisted steering. This lets you change it from Late to Early which will keep the car more in the middle of the road and not bouncing from edge to edge.
Enable Time of Steering Assist Menu
[8E - Image Processing]
[Security Access - 16] Enter 20103
[Adaptation - 10]
[Menu for time of assisted steering] Select Activate
[Adaptation - 10]
EDIT: Nevermind, found the answer on audizine...you have to turn the car completely off and back on to see it --> C7 A6/A7 & S6/S& VAG COM list and help - Page 17
#63
Auto front parking sensors
Hey,
I just coded our new Q7 so the front parking sensors come on automatically when close to an object without lowering the music volume or turning on the full parking system. A small graphic shows up on the screen with distance indicator and it will beep eventually.
Is there a way to code this feature through VCDS on the 2016 A6 FL? I really like this feature because I don't have to manually push the P button in the dash...
Any help is appreciated.
#64
Hey,
Is it not the same coding for the 2016 A6?
#65
I searched the internet but couldn't find any VCDS codes to activate the front sensors on older Audi models.
#67
Hi guys,
on a 2016 A6 Competition 3.0 TDI, with VCDS and following the tricks posted here and on other forums, I was able to:
- Enable “memory” for Stop&Start;
- Disable seatbelts reminder chimes;
- Enable electric bootlid closing from key and driver's door switch.
Instead, it seems that it is not possible to enable the “parking brake release without seat belt on”. I followed the instructions you already know, that means:
[Select]
[53 - Parking Brake]
Code presented by program
[Adaption - 10]
Select from drop down menu
Change parameter
In particular, from the drop down menu I selected “ENG101131 – Seat belt buckle detection” and changed it from “activated” to “not activated”, but then the parking brake still does not release if driver’s seat belt is not fastened.
Is that the correct channel in the drop down menu to be changed? I didn’t find anything else more relevant. Did someone make this work on 2016 FL models?
Thanks for your help!
[Select]
[Adaption - 10]
Change parameter
#69
Hey,
Can you provide the instructions for this? I'd like to have this. I'm wondering if it will work on my '14 A8L.
#70
I found this coding at VCDSCODING.COM could somebody give me advice and tell me if I should try it in my 2016 A7? I'm in the US.
Thank You Very Much.
[Traffic Sign Assist Activation]
Select STG 5F (Information Electrical)
STG adjustment -> function 10
Select channel (63) vehicle function list BAP traffic_sign_recognition_0x21
Değer=Active
Select channel (151) vehicle menu operation-menu_display_road_sign_identification
Değer=Active
Select channel (153) vehicle menu operation-menu_display_road_sign_identification_over_thresho ld_high
Değer=Active
STG A5 (front / advance camera)
STG Access Permission -> Function 16
Access Code 20103
STG Long Coding -> Function 07
Byte 1
Bit 0 Activate - "01 Traffic Sign Recognition (FTE) active"
Select STG 17 (dash panel insert)
Byte 5
Bit 2 Aktivate
Select : channel numbers indicate end of speed limit
Importance to actively invest Show Valid suffix
View Channel Valid suffix
Corresponding value adjust default: 00100111
Değer=Active
Değer=Active
Değer=Active
Access Code 20103
Byte 1
Byte 5
Bit 2 Aktivate
I am going to 5f, Adaption-10, channel 63 and there's nothing to see.
I suppose a Security Access is needed to access these channels to activate traffic sign, Any help with this?
Thank you!
