VCDS data request
VCDS data request
Could someone with VCDS please check whether Advanced Measuring Block 053 in the 53 - Parking brake module actually tracks the transmission selector?
In my car it does not, and I'm suspecting this is why S6 folks haven't been able to get the automatic engagement of the parking brake to work when selecting Park on the transmission.
Mine shows Neutral in any position, even when the reverse light switch (I forget which block that is) shows as active.
TIA!
TIA!
Thanks! I seem to recall a bunch of ECU parameters like requested torque, etc so if the EPB knows you're trying to roll away I don't know that it cares if you're in D, 1, 2, etc... It's *entirely* possible that I'm barking up the wrong tree, and I doubt this is something we could "fix" anyway, but I was surprised the "auto-engagement" mode didn't work for me or the other S6 poster I saw try it...so I guess it's just my nature to want to know why
Swing and a miss.
Richard - I tried it tonight and no go. Showed exactly as your screen shot. Tried with the car switched on but not running, also with the engine running. No difference. Tried all gear selections (P/R/N/D/M) and the screen always said "Neutral". Car is a 2013 A6 3.0T Prestige.
If so I guess I'm looking in the wrong place!
Thanks again!
Have any of you been able to activate the "Shift P to EPB" and have the parking brake actually automatically apply when you put the car in Park?
Seems like either none of us (without the transmission gear showing in the measuring block) can, or there's some other mechanism at work.
I suspect the folks with the "normal" 8spd auto will work and it's some S-tronic thing, but maybe the feature's just gone now...
Totally different subject, I am wondering if the US tail-lights can be coded to act as if they were the ROW tail-lights? In the US case, rather than have the entire left side blink, just the top LED strip blink...meaning the brake lights are working on both sides.
Not sure if that is clear or not...but yeah....
Specific to the parking brake question...while looking on some of the UK Audi VAG-COM Forums, there is a functional difference between two part numbers -
Works -
Does NOT work -
Note the difference in part numbers. That might explain why this can't be enabled with US versions. The question now is....who is going to go and check the P/Ns??
Works -
Code:
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 G HW: 4H0 907 801 A Component: EPB-4 H03 0014 Revision: -------- Serial number: 00000000884018 ASAM Dataset: EV_ParkiBrake 001028 ROD: EV_ParkiBrake_AU48.rod VCID: 2C537C7E47CB1B7E17F-8079 No fault code found.
Code:
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 E HW: 4H0 907 801 A Component: EPB-4 H03 0012 Revision: -------- Serial number: 00000000316756 ASAM Dataset: EV_ParkiBrake 001022 ROD: EV_ParkiBrake.rod No fault code found.
Code:
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 H HW: 4H0 907 801 A Component: EPB-4 H03 0015 Revision: -------- Serial number: {redacted} ASAM Dataset: EV_ParkiBrake 001028 ROD: EV_ParkiBrake_AU48.rod
Link to other forum thread?
