01 A6 no crank
01 A6 no crank
So I bought this super clean A6 yesterday, for pretty much nothing. Kid said it wouldn't start so i had it flatbedded home. Battery is ok, everything lights up when the keys on but it wont even click the starter. i'd like to try to diagnose it without pulling the alt out.
whats the best way to jump the starter? any other hints to why its not starting?
cars an 01' a6 2.7 w/auto
So you have no idea if the engine is okay or totally trashed? Before jumping or otherwise turning the engine over you may want to verify you won't do damage by doing so. If the timing belt is gone the valves will interfere with the pistons, thus trash stuff. Or, maybe that has already occurred. What about trying to turn over the engine manually? Or, if you are new to Audi, maybe finding a competent technician to assist? There is likely a reason the car was cheap.
Use a jumper battery.
Won't start or won' crank
What is the best description you got from the kid when it died.
Was driving vs. was not?
Ran and died vs. decided not to start?
If it is a no crank, start with fuses, ignition switch, shift and brake lockouts, etc.
Jesus christ, I'll pull the alternator to check the starter.
I'm not really sure how any other conditions you guys have posted would be remotely related to why a starter isn't engaging except for that last post, but I'll bite.
Yes, I've heard the car run before. Yes, it bars over fine. No, this is not my first audi. No, the reason he sold it is because he's a swag/Yolo kid that just inherited a trust fund. Reguardless of the price, the rims cost $1400, I found the invoice, they're more than double what I paid for the car and if all else fails I can slap them on my 02 a6 and I still come out on top.
A little confused how pulling the Alt checks the starter, but I'll bite?
Since you have a C5, you probably know the drill.
Just start with the battery and the ignition switch and work your way towards the starter.
Or start at the starter and work back.
Really I just want to know where the other end of the starter trigger wire goes to before it gets lost in a harness (terminal #50 on the starter)
If the same as a 2000 2.8, the "Starter Interlock Relay" pin #9 Brown.
On its way there it goes through a 2 pin connector under the hood on the right and to the electronics box in the plenum are under the hood.
are you getting the 12v to fire that starter solenoid ? I had an issue once where that wire was completely corroded and had to cut it back a fair bit and splice in a new piece. Pretty well comes down from the ignition switch so the ignition switch should be high on the list if you are not getting the 12v.
If you are getting a good strong 12 .x volts when you go to start but the starter still isn't firing there is a very good chance the braided wire from the solenoid to the starter is fried , I have had this happen 3 times now and is fairly common on the Bosch starters. However it usually happened because something is blocking the engine from turning over and it fries. I would put it in neutral as suggested and try turning it over by hand just to see.
Oh one additional note . On the 2.8 the starter is fairly easily removed through the passenger wheel well after removing the CV heat shield , no need to ever touch the alternator, not sure about the 2.7 T though but may want to look into it , as you are correct, removing the alternator is a royal pain in the ***.
