1998 Audi a6 quattro 2.8l. Code p1423
#11
This is whats under the ecu in top right underhood i was told by a clerk at german motorsports that i have to go underneath this and the tcm to get at the fuse. Is that right?
Fuse arraingment in manual
Fuse arraigment in car
#12
All right so went to work under the hood today and no luck! I did not see a j299 relay or a 40amp fuse located in the ecu. Also my fuse arraigment was different then one in car compared to owners manual.
#13
Your in the wrong area
First off the UCU/relay/fuse box is on the drivers side under the cowl cover and is secured by screws with a hex head, secondly the picture from the manual is showing the fuse arrangement on the interior drivers side of the dash with the door open.
#14
Okay so i remove the cowl cover which is underneath the steering wheel where my kness r its like a protector from my kness hitting the wires right?
#15
Or you are saying to remove those hex head screws i see in the pic of the cars fuse box and get behind there correct? German motor sports daid i have to remove windsheild wipers and crap
#16
There one bolt back there lift the plastic up a little and u can get ratchet in there
#18
Yes, under the hood in the rear pull the rubber weather-strip gasket off and pull the cowl cover off "that covers the battery" then read this link https://www.audiworld.com/forums/a6-...moval-2861524/
#20
