2.7T Cam Chain Tensioner Replacement Problems
Old 09-22-2014, 08:44 AM
  #11
CRuby's Avatar
Originally Posted by Metronet
Wow, CRuby those are really nice pictures you've got.
Wish I had those as a reference when I worked on my 2.7T... oh well. Thanks for sharing!
Yeah I wish I had them too, when I was starting my troubleshooting. Created as I went. Bentley manual wasn't as helpfull as I hoped, as it did not mention anything about differences btween bank 1 & bank 2 intake sprockets.
Doing tensioner swap w/o engine @ TDC just makes it easier to mess things up. Engine should be @ TDC (FYI, that's cyl #3 compression stroke), align notches on cams to arrow marks on bearing caps, & have correct chain roller count between exhaust & intake. If you are replacing the tensioner, I suggest you double check the part number to confirm you have the correct side. Left & right look alike, fit-up alike...but are not alike!. Different part numbers, & they work differently.
Old 09-22-2014, 01:26 PM
  #12
Metronet's Avatar
+1
One pushes up and the other tensions down, both 22 degrees VVT. I've read someone used the Passenger side's cam chain tensioner from the V6 on a 1.8T with VVT disabled since both passenger side have part number -088 (For some reason the 058109088K for the 1.8T is more expansive to buy online).
Can 2.7T and 1.8T AWM Cam Chain Tensioners be Swapped?
Old 02-03-2016, 07:52 AM
  #13
Byron Curtis's Avatar
Thank you Cruby. I will use this on my 04 a6 2.7t
N'Syncro
33
02-16-2020 03:12 PM
Boosted01tt
1.8T Discussion
01-03-2017 05:55 PM
firemandan
09-15-2015 08:02 AM
cameltrophyallroad
Audi allroad
09-04-2015 05:40 PM
ECS Tuning-Audi
09-01-2015 12:25 PM
Quick Reply: 2.7T Cam Chain Tensioner Replacement Problems
