2.8 Variable Volume Intake Manifold Test
Old 01-30-2015, 10:39 AM
blink's Avatar
Default 2.8 Variable Volume Intake Manifold Test
Does anyone know how to test if the variable volume intake feature on the 2.8 is working properly? Its the diaphram/lever contraption under the coil packs.
Old 01-30-2015, 12:26 PM
jcman's Avatar
A vacuum solenoid is actuated at 3200 rpm maybe a bit higher to advance the manifold change over valve or tuning spool, have someone rev up the engine and watch the vac actuator lever move.
Old 01-30-2015, 04:21 PM
SloopJohnB@mac.com's Avatar
Default Won't VCDS actuate it at engine idle?
I don't know for sure, but it seems that's one way to see if it works. Whether it works at 3200 is another question, perhaps by logging while driving?
Old 01-30-2015, 06:30 PM
blink's Avatar
The rpm +3000 worked. It actuated. I'm unclear of the actual rpm value that initiated the vac, but it was above 3 below 4. I tested, as jcman suggested, on startup a few times without any reaction from the vac solenoid. I was trying to keep everything cold while testing. It turns out, after it ran for a few minutes, the vac solenoid would initiate. Went back and tried it on a cold start, and there was nothing. Few minutes later, actuated fine. The word of the day is actuate, and initiate.
Old 01-31-2015, 06:33 AM
Default Good on you! Glad to hear it worked after a few minutes.
That's probably the time it took to get out of open loop startup mode.
Old 01-31-2015, 03:40 PM
jcman's Avatar
Default A reaction apon an action
Ha you got me, yep the vac solenoid is Initiated via ECM so the vac diaphragm can be Actuated to rotate the change over valve by a lever.
Those words of the day must be in a mechanical order too.
sullyj
9
08-21-2017 07:31 AM
S4444
2.7T V6 Discussion
06-25-2008 03:46 PM
frankk
03-23-2005 05:52 PM
james shannon
11-29-2001 02:49 PM
Quick Reply: 2.8 Variable Volume Intake Manifold Test
