2.8L oil cooler gasket warning - AudiWorld Forums
Old 01-10-2014, 07:33 PM   #1
Default 2.8L oil cooler gasket warning
I have a 2.8L 30v AHA engine, for many months I had noticed a very slow leak from the rubber O ring gasket behind the oil cooler. I tried tightening the oil cooler, didn't stop the leak. So I bought a new gasket, then winter arrived, so I put it off installing it until spring. Earlier this week, it was around 1F here in DC, so I went out and started the car to allow it to warm up, when I went back out to the car there was a HUGE POOL OF OIL under the car and the engine was clacking, I immediately shut down the engine. Turns out there was two complete breaks in the gasket and oil was shooting out like a fountain. It's all fixed now, but had I not come out when I did the engine would have been running with no oil and destroyed it. If you have a slow leak as I did I would replace that $6 gasket immediately. It is a b*tch to replace, that rear water hose connection is hard to get to.
autlaw is offline   Reply With Quote
Old 01-10-2014, 08:06 PM   #2
Tech Guru
4Driver4's Avatar
Bummer.
Actually, it's easy to replace. You don't have to disconnect the hoses from the cooler. You can unscrew the pipe from the block. Adds an extra 15 minutes to an oil change.
I keep a few spares on the pegboard because they are such a common failure item, especially in the cold.
4Driver4 is offline   Reply With Quote
Old 01-11-2014, 06:32 AM   #3
wow, I didn't know that, yes that would have saved a lot of time on the job. What's the trick to removing the threaded pipe since the only nut I see on it is the one that secures the cooler? Is there another nut on the back side of the cooler against the block? I'll be keeping a spare now as well. it was like a fountain, there was so much oil on the ground that it must have been most of the oil in the engine, the valves were really clacking. That 2.8L takes a licking and keeps on ticking, I really thought I had internal damage. Once I put oil back in and let it warm up all the valve noises went away.
Old 01-11-2014, 06:35 AM   #4
Tech Guru
4Driver4's Avatar
Definitely lucky.
Once you take the nut off, slide the cooler away from the block. You should be able to open a 1/2 inch gap. Sneak into the gap with a small pair of channel locks, gab the pipe, and twist it loose. As soon as it breaks free, you should be able to unscrew it by hand.
Old 01-11-2014, 06:46 AM   #5
Default thanks
Quote:
Originally Posted by 4Driver4 View Post
Definitely lucky.
thanks 4driver4, I really appreciate your quick responses and I know that your vast knowledge is well-respected here.
Old 02-06-2014, 10:34 AM   #6
Your thread came up when I did a search as I had exactly the same thing happen to me this morning, except for the clacking.
Mine is a 96 A6 2.8 12V and temp this morning was -30 C.
The car started quite well actually but when I checked on it a few minutes later I heard a rythmic sucking sound and immediately shut it off. Big pool of oil under the car. I removed the belly pan and the oil is clearly coming from right above the oil filter housing.
I know this isn't the C4 forum, but would that indicate the oil cooler gasket on this car as well?
Fuzzydog is offline   Reply With Quote
Old 02-06-2014, 10:36 AM   #7
Tech Guru
4Driver4's Avatar
Same thing.
Old 02-06-2014, 10:44 AM   #8
Thanks very much and I am relieved that it will be a relatively easy fix.
Sure not looking forward to doing it at the current temps though!
Old 02-07-2014, 10:26 AM   #9
Heard yhe best way to get it out is take out the nut the filter is connected to... im having the same issue only my audi died out when i was going outside i seen the pool of fluid checked the oil level it read min so im hoping the car died out to prevent vavle damage n not cause it already damaged them....
werick is offline   Reply With Quote
Old 02-07-2014, 10:55 AM   #10
SloopJohnB@mac.com's Avatar
Quote:
Read what 4D4 said…the nut gets taken off, the cooler adapter (the aluminum block between the oil filter mount and the engine) is slid back ½" or so, the threaded pipe is loosened and removed or moved back enough to get the old gasket out and the new gasket in, put the threaded pipe back into the block and tighten it a little, then slide the cooler adapter back onto the new gasket and put the nut back on the threaded rod and tighten the nut appropriately.
SloopJohnB@mac.com is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Mk1 tt overheating at idle Boosted01tt 1.8T Discussion 5 01-03-2017 06:55 PM
1995, 90 Quattro - low oil pressure light/buzz at 2,100 rpms + hardipk5 Audi 90 / 80 / Coupe quattro / Cabriolet 17 11-24-2015 04:42 AM
Oil pressure warning light ay6 A6 / S6 (C6 Platform) Discussion 4 09-11-2015 04:47 PM
Cam tensioner help/advice Tahoesilvers4 Audi allroad 1 09-10-2015 07:08 PM
how much ATF fluid do I need? bilbo6209 A6 / S6 (C5 Platform) Discussion 14 09-04-2015 02:57 PM
Tags
2000, 2001, 28, 28l, a6, adapter, audi, cooler, gasket, leak, location, oil, removal, replace, replacement
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
