cannot stop power steering squeel
Old 09-16-2018, 10:44 AM
a6wrenchin's Avatar
Default cannot stop power steering squeel
2001 a6 quattro 2.8. I'm on the 3rd pump, and cannot get this thing to shut up. I've been through all the forums and done just about everything I've read. There are no air bubbles in the reservoir. I've replaced both hoses between the reservoir and the pump and all the clamps are new and tight. It's always making the unmistakable steering pump sound like its low on fluid. get's louder with rpm's. The steering is fine during normal driving, but is tight when parking at low rpm's. There's new fluid and it's been bled many times. Once with the reservoir extended and zip tied to the top of the open hood for extra gravity. I'm on my second new meyle pump and the original audi pump had the same issue. Any help or suggestions would be greatly appreciated. Thanks in advance
Old 09-16-2018, 12:46 PM
clancy's Avatar
If the sound is more of a growl than squeal I would suggest you check the filter in the bottom of the reservoir. Not sure it can be replaced without replacing the reservoir, but maybe it can be cleaned. Mine was dirty and it starved the pump of fluid making it growl.
Old 09-16-2018, 01:41 PM
a6wrenchin's Avatar
Thanks for the reply. I blew mine out with an air compressor, and it looked clean afterwards. Think it’s flowing alright there. Maybe I’ll grab a new rez just in case
Old 09-17-2018, 03:58 AM
clancy's Avatar
In my case you could not tell it was starving for fluid except for the growl. Looked okay in the reservoir when it was running. Not saying it is the cause of your problem. But I was having problems and told my tech about the reservoir filter and he did not think it was my problem. He replaced a hose which did not fix it. Then the starving caused my old tired pump to die. Replaced pump. The problem continued. He eventually replaced the reservoir and all was good. So even a good tech did not see the filter causing it. But it was.
thegingerone
03-17-2010 05:46 PM
audix
11-09-2009 12:44 AM
glidar
Audi allroad
10-16-2008 05:21 AM
sNoSTaRR
02-01-2008 11:10 PM
EricPA
07-01-2005 05:39 PM
Quick Reply: cannot stop power steering squeel
