Stuck in park. Clicking. Limp mode. HELP. A6-01
Old 08-19-2011, 11:29 AM
TedZyk's Avatar
Default Stuck in park. Clicking. Limp mode. HELP. A6-01
Hi all
My 2001 A6Q-auto was stuck in park this morning.
I heard a clicking sound from the shifter and little light next to shifter was on and blinked. Eventually got to Drive "in limp mode!" and on the dashboard "PND234" light was all red.
And check engine light came on
This happened 3 times, then the next time no problem, no 'limp mode', except 'check engine' light stayed on.
Any thoughts PLEASE.....
Best,
Ted
Old 08-19-2011, 11:58 AM
Tech Guru
4Driver4's Avatar
Pull codes, post codes. (ECU and TCU)
Old 08-19-2011, 11:59 AM
TedZyk's Avatar
Will do shortly!!!
Thanks
Old 08-19-2011, 12:08 PM
5v/cyl's Avatar
Sounds like the multi-function switch (F125) is going or gone. Codes will reveal the truth, but the code is most likely in the TCU so a generic OBDII scanner will not be able to read them. Audi specific scanner or VAG-COM will be necessary.
Old 08-19-2011, 01:03 PM
TedZyk's Avatar
Code is P0600.
Now check engine light is off.
Any chance it could be "brake light switch"
Old 08-19-2011, 01:04 PM
TedZyk's Avatar
Code is P0600.
Old 08-19-2011, 02:07 PM
5v/cyl's Avatar
Did it rain recently or did you wash the car? Check for wet carpet on the passenger side.
Old 08-19-2011, 05:09 PM
Tech Guru
4Driver4's Avatar
P0600? Sounds serious...I guess. Makes me wonder what it means.
What about codes in the TCU? Nothing?
Old 08-19-2011, 05:14 PM
tester123's Avatar
From Bentley:
16984 P0600 Serial Comm. Link (Data Bus) Message Missing.
Sounds like a short / malfunctioning unit on the communications bus. Didn't check the manual yet but, the OP can try resetting by removing battery.
Old 08-19-2011, 06:05 PM
5v/cyl's Avatar
I think this code is a result of the ECU not being able to talk to the TCU. Basically an almost total TCU failure which is leading me to believe it is wet or worse. Either way you are right that it sounds serious.
Originally Posted by tester123
From Bentley:
May be worth a try, but I doubt it will work. At this point he has nothing to lose.
Quick Reply: Stuck in park. Clicking. Limp mode. HELP. A6-01
