2001 A6 Avant washer fluid leak
Hello, noticed at work yesterday a puddle under the drivers side near front of body area out towards side of car
On investigation washer fluid dripping out of the spot welded support area that runs front to back near front where it gos up to start fire wall, there is a formed drain there it was dripping out of
Feeling around (what you can) the tank area I found nothing.
Any standard failures that may cause this?? Tank, hoses connectors pump (is working) to look at to start
Thanks for any tips in advance!
Regards
Regards
Pump grommet to tank have been known to fail.
Regards
Regards
Thanks, will look at both this evening, I am more inclined to think pump to tank as it was a big puddle and I had not been using the washers
Thanks again to both of you, will report back!
regards
regards
Skizsam
01-15-2004 04:46 AM
