Do I need to mate my new TCM to the ECM?
Old 06-13-2011, 02:36 PM
justinwallace1984's Avatar
Default Do I need to mate my new TCM to the ECM?
2000 A6 4.2 Quattro was stuck in limp mode. Replaced the output speed sensor and harness and now it will not shift out of 1st gear. I have a new TCM on hand so I figured I would give it a shot. I have been told it needs to be paired to the ECM before it will work. Any truth to this? If so can I program it with a cheap vag-com cable?
Old 06-13-2011, 08:36 PM
Redneck Truck's Avatar
Try it and see. Might pop right in. I can't fathom why you'd need to do any coding or calibrating.
Old 06-13-2011, 09:50 PM
MP4.2+6.0's Avatar
Default No you don't
I have a 2000 4.2 and have changed the TCU in the past. It just plugs in and that's it. Best if you do the learning type reset of both ECU and TCU, but not strictly necessary.
Went thru the issue w/ the output sensor on mine some years ago. I found the wiring was broken internally somehow and eventually ran a new wire from the sensor through the tranny tunnel sheet metal direct to the TCU. Check the continuity from your sensor wiring terminal to the correct terminal of the TCU end connector and make sure you really are getting a continuous signal. I wasn't.
2000 a6
03-27-2018 12:36 PM
Marco85
12-27-2015 06:13 AM
justinwallace1984
VAG-COM Discussion
06-16-2011 06:31 PM
justinwallace1984
06-15-2011 07:48 PM
Maldridge05
02-24-2008 06:02 PM
Quick Reply: Do I need to mate my new TCM to the ECM?
