2002 A6 3.0L Low Oil Level Light - Bizarre Issue
#22
Then we go back to the pick your poison on oil, synthetic or mineral and which one release's moisture or retains moisture at certain temperatures.
I will agree that if the oil is white or tan in warm/hot seasons then we should be concerned about gaskets or cracks.
#24
The ironless 3.0
I've seen the oil butter on the 01 A6 2.8 our daughter drives and in our 04 A6 3.0 with no apparent issues of oil or coolant loss other than a CCV on the 3.0 that had frozen oil butter in it causing wild idle issues and a loud vacuum hiss, I still replaced the CCV with a new one and this season I'm using Pentosin vs Shell Rotela T6 and the results look better with way less butter.
One point not to dismiss is the pcv system keeps blow-bye pressure at a norm by a vacuum draw, not enough will pressurize the crankcase causing gasket leaks and contaminate the oil with un-burnt gas and water vapor, too much draw or vacuum will cause idle/engine issues and potentially pull oil into the intake, a delicate balance of design by demand so to speak.
#25
I don't seem to have any trouble just wondering what the butter was from , sounds like in colder areas you'd get more butter. I use the Mobil 1 euro blend 0-40 synth oil. with the Mann filters. I use to use castrol 10w-40 GTX , the butter looked the same in both cases. Oil looks ok, I change it twice a year. car has 120K miles on it and knock on wood it's been pretty good so far. Just have a few things needing to be looked at but nothing stopping me from driving it .
#26
I suppose that members in Arizona or other hot dry states don't have this issue, actually I'm very sure of this.
Parsec
Q5/SQ5 MKI (8R) Discussion
13
03-18-2013 12:15 AM
bonsai
24
12-08-2005 12:12 PM
