2003 Audi A6 3.0-Radiator/Cooling Issue-??
#11
Others can probably answer; Does the intake manifold gasket pass any coolant between the head of the manifold? Or doe sit seal off any open coolant passages/spaces in the head?
If yes to either, that is another possibility.
#12
No coolant pass in the manifold just the pipes under it, hope this helps.
#13
Do any of those pipes connect between cylinders 2 and 5 specifically? The shop said they would have to pull the manifold to check the pipes/o-rings, so they didn't do that and just said I have (2) bad head gaskets without confirming. I really don't think both started leaking at the same time, and I can still hold pressure just fine.
#14
But running under the manifold without a connection does not explain antifreeze getting into the combustion chambers. (returning me to a cracked head, or bad head gasket). (Or the rare cracked block)
#15
But it holds pressure, doesn't overheat, no cross contamination, and there are no external leaks..
#19
Well, my compression test came back fine. I talked to a local Indy Audi repair guy. He also thinks it's a cracked head. TBH--I have no idea how that would happen. It just started this a few weeks ago, and I know the car hasn't been overheated. He's seen them crack between the valves(mainly on a 1.8, I think he said). He wasn't sure if the heads are/were a problem on the 3.0's.
He did suggest trying radiator aluminum powder. Since there no glue/bonding agent, he said if there is a very minor crack, it might work and it won't gum up the engine. Haven't decided on that yet....
