2004 A6 2.7 s-line tire and rim size options?
Old 08-03-2014, 06:44 PM
baubau2.7's Avatar
Default 2004 A6 2.7 s-line:need help with wheel spacer size
Ok, so I got a newer set of wheels: ALY58851 Audi A6 10 spoke wheel, Bolt Pattern: 112mm Offset: 48mm Audi Part Number: 4F0601025CP with tires 245/40 r 18 Conti's.
My OEM wheel was ET43, with 235/40R18 tires.
I Installed one wheel on the front and it is rubbing.
My question is what wheel spacer size I need:
- 5 mm the difference of offset, or
-10 mm too make up for the wider tire?
thanks
Old 08-04-2014, 02:23 PM
Just Me's Avatar
OEM is 235/45-17 i believe. Do the math on the radius. My guess is that the additional 10mm x 40% = 4mm wont make any difference, but you do need to check.
More importantly, do you knwo that the offset of the new wheels is correct? That's critical to both fitment and steering geometry.
Grant
Old 08-16-2014, 09:02 PM
deviantirish's Avatar
Originally Posted by baubau2.7
Hi, my a6 has 18 inch rims with 235 /40/18.
I found a set on rims and tires cheap the only thing is that the tires are 245/40R18. My question is can i run them, anyone else tried it?
Or if i go with 19 rims, what size tire do i need?
Any input is welcomed.
Thanks
The stock size for the S-Line is 235/40R18. I am running 225/45R18 for a bit smoother ride. I found some Nitto 235/40R18 that I am going to go with next though.
Old 08-16-2014, 09:22 PM
N_Jay's Avatar
Tirerack can give you all the information you need.
Factory sizes, +1 and +2 recommendations, etc.
Jaz.a6
Wheels & Tires Discussion
10-13-2017 06:20 PM
baubau2.7
09-01-2014 05:00 PM
SlizSam
Q7 MK 1 Discussion
08-07-2014 03:26 PM
aholloway17
10
03-02-2006 06:32 AM
aca
10-01-2004 06:14 PM
Quick Reply: 2004 A6 2.7 s-line tire and rim size options?
