Last edit by: IB Advertising
- Audi A6 C5 How to Bleed Clutch<br>Step by step instructions for do-it-yourself repairs.
Bleeding Clutch need help!
So I was driving my audi a6 2.7t 6 speed and my clutch pedal fell to the floor and wouldn't come back up. Had to tow home because I had no clutch. I noticed the brake fluid was low (below the master clutch cylinder line on the reservoir) so I think air just got in the system. I was trying to bleed it out with new fluid but I'm not sure how to get to the slave cylinder from under the car if anyone had some tips.
Thanks!
Thanks!
look near an axle flange on the trans.
Thanks!
Thanks!
Dunno…the bentley ebahn didn't say remove anything…you might have to remove the fender liner but I don't know. It looks about 4-6" away from the axle flange (transmission output flange). If that part of the trans is covered you'll have to remove the fender liner.
Clutch slave cylinder is on top left front of trans.
I could only get to it from the top. Long reach into tight quarters. I think the bleed screw is 7 or 8 mm, with cramped quarters making it difficult to turn very much. Break it loose 1st, then use clear poly tubing to snake down to a bleed pan below.
