3.0 Starting Issues Possible Timing
Old 01-03-2015, 07:16 PM
  #101
Bradshawtech's Avatar
I agree on the OP having other issues as well.
Thanks for all your info and support.
Old 01-07-2015, 07:31 PM
  #102
SloopJohnB@mac.com's Avatar
Default Dunno about Audi but GM Ford, etc. shift all the time
Originally Posted by Bradshawtech
Not sure how the damper mark could not be spot on as it is keyed to the crank sprocket for the TB.
I went to a local junk yard to reference the location of the window on the flexplate as I used the damper mark as a baseline. My engine is coupled to an automatic trans and the junkyard engine was from a standard transmission car. I put the damper mark on my engine and the junkyard engine at the same mark on the TB cover and that is where I noticed the different locations of the window on the flywheel. I made an assumption that the standard trans location of the CPS is different since when I returned to my engine I could not start all the flexplate bolts if I tried to mount it placing the window in the same location as the junkyard engine. I rotated my flexplate one more position anticlockwise and my bolts lined up perfectly. In this mounted position my window was just at the CPS location so I trusted this to be correct. When I attempted to start the engine for the first time I was nervous as could be but it fired up immediately and has run smooth ever since.
I must say that I am quite sure that my CPS is mounted in the bellhousing of the transmission and not on the engine itself. I trust your knowledge a lot but I wonder where the difference is in our experiences.
As far as the window being located just before it passes the CPS when the crank mark is lined up on the TB cover on my engine I am making another assumption that the crank mark is marking TDC #1 from my experience of old school domestic engines. I am well aware that is not always safe as the Germans have different ideas on many things.
Harmonic balances are essentially two metal masses bonded together with an elastomer. The bond can fail and the masses rotate relative to each other and therefore te timing mark moves to a wrong place. I've seen timing marks off by 50-90 degrees on GM dampers. It can be really frustrating if you don't catch it.
Old 01-08-2015, 07:22 AM
  #103
Airbag's Avatar
Porsche has had nightmares with the DMF in the past.. they moved away from it quickly.
Old 01-08-2015, 07:46 AM
  #104
Default Oh, this POS?
Although there's not an elastomer bonding interface, it looks too complicated for words!
BMW uses a DMF as well, but still.
Old 01-09-2015, 05:20 PM
  #105
I guess I didn't look close enough but I thought the damper was a solid piece since I didn't see any rubber isolation.
Old 01-09-2015, 05:31 PM
  #106
jcman's Avatar
Can't miss it in this picture.
Old 01-10-2015, 07:37 AM
  #107
Default Right outside the Courteco trademark stamp.
Pretty good thickness too. About twice GM.
Old 01-10-2015, 08:00 AM
  #108
jcman's Avatar
Yep.....
Old 01-13-2015, 10:07 AM
  #109
Airbag's Avatar
holy crap .. that thing looks like its designed to go to Mars..
Old 01-13-2015, 02:16 PM
  #110
Default Should see the Porsche GT ceramic clutch….
2004 Porsche Carrera GT Tech - Motor Trend Page 4
And that was in 2004...
IntheQ5
Q5/SQ5 MKI (8R) Discussion
37
08-28-2023 11:37 PM
Boosted01tt
1.8T Discussion
01-03-2017 05:55 PM
stormchaser1967
New Member Welcome Area
09-01-2015 01:29 PM
ECS Tuning-Audi
09-01-2015 12:25 PM
aron56
Audi 100 / A6 (C4 Platform)
09-01-2015 12:39 AM
Quick Reply: 3.0 Starting Issues Possible Timing
