6-Speed Manual Swapped 2002 Audi S6 Avant
looks like a fun car.
from the article:
This 2002 Audi S6 Avant was only offered in the USA with an automatic, but the seller has swapped in a 6-speed manual, likely from an S4.
14 pictures and full article
from the article:
from the article:
from the article:
More likely a 2.7T trans as well as rear diff (stock 4.2 rear wrong ratio).
These swaps are all over the place…they're less expensive than replacing the ZF 5speed auto but then you have engine ECU remapping to do, etc.
$10-12K for one with under 100K miles is more reasonable.
Just got mine back and I don't think I could be much happier. Differential ratio was the same btw, no swap needed. I did do a custom driveshaft rather than use the spacer, just wasn't comfortable with it. With an unmodded 4.2 and not driving like a teenager I think I'll be alright without the V8 tranny, time will tell I suppose.
Brian
Brian
Get it done by the guy in AZ?
Brian
Brian
Az Parts
Got the parts from Audis4Parts in Tuscon and had Bluewater performance do the install here in Denver. Both did a good job. A few issues along the way but everything worked out.
OK, rub it in! Cost me about $6K out the door for new auto trans.
I guess I could have swapped a six speed but I was worried about emissions/driveability in an emissions inspection state (MD) as well as getting it to AZ. That would have cost more plus the flight to pick up the car.
eduardo canet
02-11-2017 06:11 AM
bugzy SoCalEuro.com
12
11-10-2004 11:57 PM
jason in toronto
09-26-2001 03:52 PM
