98 audi A6 aha 2.8l timing belt replacement
Old 10-31-2013, 07:56 PM
spogle's Avatar
Default 98 audi A6 aha 2.8l timing belt replacement
Hi out there.
Im trying to get my daughters car back on the road asap. I think i really might of hosed her car up. I tried replacing her tb after installing a new water pump, t stat etc. I saw a video of a guy succesfully doing this by marking the belt and pullys in a few different areas and put it bak on and it started right up.
So I thought I would give it a go and did the same thing.. all of my marks lined up perfectly without a hitch, i started it and it ran a bit rough so i shut it off immediately. I tore back into it and lined my crank pully to the timing mark and noticed that the belt adjusted because the cam on the left was a hair off to the left and the cam on the right (driver side) was a hair off to the right. So I broke down and bought the 3391 cam lock and the 3242 crank hold pin tools. I re did everything perfectly and it tries to start but it doesnt.
My question is, could i have bent some valves being off just a smidge? Im afraid i already know the answer, but still in denial..
Thanks for any help!!
Old 10-31-2013, 08:31 PM
spogle's Avatar
This is a pic of the cam positions at tdc after tearing it back down.
Old 10-31-2013, 10:08 PM
turbo510's Avatar
Being a "hair" off shouldn't have led to bent valves, if you are you talking one or two teeth max. But bent valves always result in compression loss, so you could get a gauge and check that.
So it ran rough with the timing off, but won't start at all with the timing set correctly? That seems odd.
Old 11-01-2013, 02:55 AM
Tech Guru
4Driver4's Avatar
Lawnmower syndrome. Foot to the floor, crank until it starts.
Use the tools first next time <shakes head in dismay>
Old 11-01-2013, 06:15 AM
spogle's Avatar
I know, it doesnt sound right does it. I was thinking loss of compression due to being off time as shown in my picture. I will stop bye after work and grab a compression gauge and check it.
Hopefully i flooded it or something..
There is just not enough time in a day.. I have 6 little ones, 2 in soccer seems we are at the fields both Saturday and Sunday and practices during the weekdays etc.
I seem to opt for the quick/easy methods.. next time I definetely will buy the correct tools.. Murphy has no sympathy for short cutters does he?
Old 11-01-2013, 06:27 AM
Tech Guru
4Driver4's Avatar
Google "lawnmower syndrome audi".
Old 11-01-2013, 07:12 AM
MurderedA6Avant's Avatar
Hi out there.
Ok so the tools won't do what they are supposed to do UNLESS you FIRST pop loose the cam gears with a puller....are you getting a check engine light any codes?
Old 11-01-2013, 07:18 AM
Go to harbor freight and get the vaccum/fuel pressure tester and hook it to the port that goes to the fuel pressure regulator...if you have a smooth needle reading at idle, the cam timing is not the problem...if you need help you can google vaccum gauge testing but this is the best way to diagnose a running engine...a good reading is above 20inches of vacuum...if you have a steady low reading you have an intake leak
Old 11-01-2013, 08:44 AM
turbo510's Avatar
Originally Posted by MurderedA6Avant
...this is the best way to diagnose a running engine...a good reading is above 20inches of vacuum...if you have a steady low reading you have an intake leak
But he said that he doesn't have a running engine, so he has to determine why that is first.
Old 11-01-2013, 06:11 PM
spogle's Avatar
Thanks all for your help!!
Wow there is so much to say in reply, im on my tablet so so each letter is a slow painfull hen peck, not to mention the corrections. So please bare with me!
4driver4
That is a good possibility, this actually happened to her car last year. I tried to start with my foot all the way down the other night with no luck. I remember thats how i got it started last time.
I havent tried a cap of oil in each cylinder yet.. Also the car's front end is still in the air on jacks, wonder if this would make any difference or not?
Murdereda6avant
I wanted to pull the cam pulleys this last time after I got the tools, but I got a wierd tink sound and it felt as if I was tightening that cam bolt up. I couldnt find any specific information as to which way to loosen, I went counterclockwise and it felt like the bolt was going to break. So I opted to try to see if I can get the belt tight enough between the crank,idler,and driver cam and I did, then i threaded under the waterpump over the pass cam real tight and then over the tensioner. I then pulled the pin and torqued he tensioner 11ft lbs counterclockwise. It turned out good, then i took off the cam lok tool and removed the crank holding pin and turned the engine 2 full rotations and back to my mark and was able to get the cam lock bar back on with just a tiny amount of downward pressure on the pass side after placing it on the driver cam, i mean tiny.. so yeah its still maybe not perfect. I would like to do it the way you suggest this Sunday afternoon. Also I did not mention this before, the crank pully doesnt exactly fit snug on the guide pins, meaning I can loosen all 8 bolts and rotate about an 1/8 or so back and forth? So I split the difference? I think the 3242 tool might of fit into a hole so that there is no discrepancy on crank placement, does that sound right??
Also about the fuel pressure, her car ran perfectly good before I touched it, as most things. Im getting used to it now, I still have to hear it though from my better half.. "See told you, you should of took it in, no one listens to me!!" Lol.. Im sure we all get a little taste of this now and again..
Quick Reply: 98 audi A6 aha 2.8l timing belt replacement
