Center Jack Point; front and/or rear
Do our cars have a center jack point for lifting the front or rear?
I usually put the jack stands at the side jack points and many cars seem to have a place to put a floor jack to lift the whole front or rear.
Any think like that on out C5 models?
I don't need to do the front yet, so I will have to look at that the next time it is on a lift. The drawing I have of the part makes the center look a little "spindly" to be carrying all the weight.
I looked at the back, and it would seem a block of wood can easily span the mounting piece at the back of the rear diff and the cross member pieces it attached to.
That would seem a little safer then just the bottom of the diff (and/or the bottom of the diff mount)
(I am guessing a log of people are actually lifting from the diff mount and not the diff itself.)
Let me know what you find?
... I spend far too much time jacking under the pivot points for the F & R control arms - the known strong points where the frame bolts to the body, and the contorl arm bolts to the sub-frame. PITA, but safe.
G
G
Ended up under the rear diff and diff mount with a 2x4 on my floor jack.
I found my jack stands nicely cradled the rear suspension pivot points very securely.
Now that the rear brakes are done, I do have to put it up one more time as the rear diff is a bit wet (not dripping, but well coated). I am holding off on the axle seals, but want to top up the diff oil to make sure there is enough to go a year or so till I get to the seals.
Cheap insurance. Better a little extra work now than a bad diff later.
center rear jacking point? Front is on jackstands, need to get the rear up. Diff case strong enough?
Bimmer Needs Reverse
09-27-2008 08:15 PM
quadroped
03-26-2008 08:31 AM
