A6 4.2 owners, I went ahead and ordered up some aluminum Oil Cooler Pipes.
Old 10-25-2009, 02:49 PM
  #21
A6 4.2 litre's Avatar
Here is what my plastic H2O pipe looked like at 92K (sorry for the bad pic).
Purchased one of Jim's replacement parts. Fit perfectly.
Old 10-27-2009, 10:05 AM
  #22
NJA642's Avatar
I suspect mine looks the same; thx for the feedback.
Old 10-27-2009, 11:04 AM
  #23
fusilier's Avatar
Hi guys,
If you need a repair pipe (aluminum), please PM me by clicking my name here on Audiworld. Thanks
James
Old 10-29-2009, 08:47 AM
  #24
mswanson65's Avatar
I am habing timing belt service soon. Is this an appropriate time to correct this oil cooler pipe or is it a completely different effort. If it is separate should it be done when you notice failure or done ahead of time? any opinions? thanks!
Old 11-05-2009, 10:05 PM
  #25
finbust02's Avatar
Originally Posted by fusilier
Hi guys,
James
Could not PM you. Inbox full? I have the dreaded coolant leak from behind the oil cooler... 54K. I need a pipe.
Old 11-09-2009, 07:10 PM
  #26
eagledubg's Avatar
im having the same problem pm'ing you i def want one as well..
Old 05-30-2010, 05:59 AM
  #27
alxjhn's Avatar
Default aluminum pipe
hey needed a pipe please email alx517@gmail.com with payment info... It fits 2001 audi a6 4.2 ?
Old 06-01-2010, 08:43 AM
  #28
quattzilla's Avatar
Man, I wish I had this insight about 8 months ago... I could have saved big $$$.
Back then I had my T-belt procedure performed, and the oil cooler pipe started leaking on me about 2 weeks later. Apparently the pressurization performed after replacing the coolant was just enough to push those brittle little pieces in the oil cooler pipe over the edge. It's a fairly common issue with the 4.2 V8's (I came too learn a bit too late).
Long story short; I ended up having to pay another $800 to have this fixed just a few mere weeks after they had the whole front end out for the timing belt.
Therefore, if I were you, I'd just replace it during the T-belt procedure as a safety precaution.
Old 11-15-2011, 07:16 PM
  #29
v8a6's Avatar
Default I need one too
I need to buy one of these too. I just sent you an email through Audiworld since your account no longer allows PMs.
Old 11-16-2011, 05:00 AM
  #30
SloopJohnB@mac.com's Avatar
Google Bufkin Engineering...
Quick Reply: A6 4.2 owners, I went ahead and ordered up some aluminum Oil Cooler Pipes.
