A6 4.2 Tailshaft flange seal repair...
#11
The Audi shop I am using wants $198 for labor and $12 for the seal
(Of course $20 each for exhaust clamps and $30 for a liter of gear oil)
I need to find a friend with a lift.
#12
If your heat shield screws broke, the only thing left is to drill them out like I did.
#13
5k miles after the entire job, still not a drop of oil leaking anywhere and the car runs like brand new! Can't ask more than that (for now at least )
Don't we all?
#14
Try Blauparts Ravenol Gear Oil (75W-90). It works perfectly and is OEM equivalent. I am not associated with Blauparts but, so far, all my experiences (t-belt kit, Trans kit with fluid, Tie-rods, coolant and gear oils etc.) all have been positive and I am very happy with them.
Don't we all?
Don't we all?
Since those guys are just up in WI, I might try them out.
#15
what i meant to say was i did not completely remove it from the car .. just dropped where it attached to the tail flange and dropped the support bracket and swung it out of the way ..
#16
Well, this car has not spent much time in the salt, so hopefully I won't run into the stuck screw issue.
I also need to do both axle seals on eth rear diff. Those should be easier.
#17
Well, YMMV but I just replaced both boots on Front Driverside axle on my 4.2. The Triple roller joint (inner CV joint) WILL NOT come out as the end of the lip is punched to prevent the rollers sliding out. You can press them if you a good vice etc. and take it apart. Too much work/hassle for me. I just cut the boot out, cleaned all the grease using GAS and brake cleaner. Needed to replace both boots anyway so, I removed the outer CV boot and hammered out the inner racer (there is a "C" clip that holds it in place). Pulled everything off the shaft and slide the inner boot on. This way, I didn't have to mess with triple roller side. Rest is outer CV boot, grease, new hardware and clamping it down.
d6lc
06-19-2013 05:43 AM
watusimanu
10-24-2011 07:51 AM
slychicken37
Audi allroad
09-25-2011 06:51 PM
ebony andras
11-05-2005 08:45 PM
