A6 Steering Column Cover Removal - AudiWorld Forums
Old 10-25-2009, 09:58 AM   #1
Default A6 Steering Column Cover Removal
So far I have removed the 2 torx screws from the underside of the cover & the 2 phillips screws in the front of the lower cover. Lower cover just will not come off. Appears to be some attachment point near the steering wheel, but I can't see anything.
I need to replace the W/Washer lever assembly (my 19 year old broke it off somehow).
HELP!
bfbarosky is offline   Reply With Quote
Old 10-25-2009, 10:57 AM   #2
radhaz's Avatar
Looks like you need to remove the steering wheel.
radhaz is offline   Reply With Quote
Old 10-25-2009, 11:28 AM   #3
Tech Guru
4Driver4's Avatar
I've done this, but I don't remember. When I did the evaporator swap, I used Bentley. I have a fair amount of Audi experience and mad skilz, but after using Bentley it is clear to me that I would have broken a ton of plastic parts if I had not carefully followed the Bentley.
4Driver4 is offline   Reply With Quote
Old 10-27-2009, 01:21 PM   #4
AudiWorld Expert
Boston Driver's Avatar
There is one more torx bolt near the tilt lever on underside, but you will need to remove the steering wheel anyway to replace the wiper stalk.
Refer to this article which gives more detail on the stalk replacement (for the signal stalk but they are attached to each other): http://www.audiworld.com/tech/elec162.shtml
Refer to this writeup for info on the steering wheel column trim for a non-4.2 (my 2.7T):
http://forums.audiworld.com/showthread.php?t=1702901
Good luck!
Boston Driver is offline   Reply With Quote
Old 10-31-2009, 06:21 AM   #5
Good luck!
Many thanks. This is my project for next weekend. Need to find the parts first.
My A6 also has the turn signal problem you mentioned. But mine makes a very fast clicking noise in the dash, behind the radio - Relay Problem???
Usually, after I operate the 4-way flashers for a few minutes, the turn signals work, but only for a few seconds.
Thread Thread Starter Forum Replies Last Post
DIY Remote start Q5 IntheQ5 Q5/SQ5 MKI (8R) Discussion 27 06-09-2016 01:37 PM
The Daily Build..My S6, the story and the questions vwleadfoot Audi Original "S" Cars 4 12-24-2015 07:07 AM
How to remove steering line retainer? Zumkopf A8 / S8 (D2 Platform) Discussion 1 09-10-2015 06:23 AM
No Start, Need Codes Diagnosis eggsngrits A8 / S8 (D3 Platform) Discussion 0 09-05-2015 11:22 AM
95 Cabriolet Power Window Issues. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-02-2015 10:02 AM
Tags
2001, 2002, a4, a6, audi, b6, column, cover, removal, remove, removing, road, steering, tt, wheel
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
