A6 Symphony Hidden EQ settings
Old 07-29-2001, 01:12 PM
  #11
mpuzach's Avatar
Default It definitely works on my 2000 non-Bose.
Tried it yesterday, though in the end I ended up putting everything back to the factory settings. I'll play around with it again when I have more time.
Old 07-29-2001, 02:33 PM
  #12
AudiWorld Expert
2.7tDallas's Avatar
Default 65356444 worked best for me (more)
the 65356 is right on the money. You are correct about the better sound.
444 at the end since my band pass box already does a great job down there. I might go to 454 and see, but otherwise yyour advise was great!
Old 07-29-2001, 04:42 PM
  #13
Stoney's Avatar
Default Audiablo: Experiment only with fader all the way to front or back...
The settings you describe won't change the tonal balance...Only the volume. The first 4 are front settings, the second 4 are back.
Settings like 99991111 and 11119999 simply lower the front speaker volume across the spectrum while raising the rear speaker volume, and vice versa. Try instead 96319631 or 13691369, and you'll hear the difference.
Tip: ALWAYS experiment with one pair (front, back) at a time!
Old 07-29-2001, 05:01 PM
  #14
Stoney's Avatar
Default Symphony: the first 4 digits are front spkrs, second 4 are back. Here's how to do it...
The readout says 55555555 initially. Each digit is a band for either front OR rear speakers.
"ABCD EFGH"
A= low bass front
B= upper bass front
C= lower treble front
D= upper treble front
E= low bass back
F= upper bass back
G= lower treble back
H= upper treble back
What this means is that the EQ bands are really wide, not quite narrow enough to fix some of the problems I hear. But the bands are narrower than the three tone controls in the dash.
How to do it:
First, access the settings... see <A HREF="https://forums.audiworld.com/a6/msgs/75310.phtml">this message</A>. Then, follow these steps:
1. Use well-recorded natural sounding CDs (preferably not synth or dance music).
2. Don't use FM stations because they all sound different.
3. Set the tone control ***** to flat. These you will use later only to adjust between sources (CDs, tape, FM).
4. Listen at a loud level so you can really tell what band sounds too loud or too soft.
5. Always experiment only with front OR rear speakers, using the fader at one extreme or the other.
- Adjust the fader so only the front are playing. Then adjust the first 4 digits until it sounds flat on several songs or CDs. Keep the settings near 5, and only change those bands that need a little more or a little less. In other words, 9999 is not a useful setting.
- When done, shift fader to rear, and adjust only the second 4 digits. Your goal is to make the front speakers sound like the back speakers, which should both sound like live unamplified music.
- When done, set the fader where you like it and check that it sounds good.
- In my 2001 A6 4.2L sedan, I thought that 6535 6474 sounded pretty flat, perhaps a bit bass-heavy if you play it loudly.
6. If the bass still sounds too bloated in the upper bass or too undamped (lags behind the music), then try either putting towels or other damping material next to and below the woofer in its compartment, or try also putting some taut electrical or duct tape across part of the port in the side of the woofer, as someone else here has recommended <A HREF="The readout says 55555555 initially. Each digit is a band for either front OR rear speakers.">at this link</A>... the more of the port is blocked, the more effect it will have. I haven't tried the tape trick, so I can't comment. You can also try leaving the compartment door off.
Another option is to add a crossover to the woofer. I don't think Bose rolls off the highs, at least not by much because the highs still can be heard rather loudly out of the woofers. One could make a crossover and add it to the system. I'd try a 6 dB rolloff at around 100 Hz. Any more effort than this, the woofer doesn't deserve... just replace it.
Old 07-30-2001, 04:38 AM
  #15
Member
Jim De Arras's Avatar
You have to turn ignition key off for settings to take, not realtime adjustable.
Old 07-30-2001, 09:57 AM
  #16
Junior Member
Audiablo's Avatar
cool... separate EQ's for front and rear speakers
Old 07-02-2002, 12:48 AM
  #17
New Member
Vhavhu's Avatar
How do I access this EQ on Concert Radio ?
Old 08-20-2002, 05:45 PM
  #18
Bruuster's Avatar
Default What happens when holding the #3 button?
The hidden EQ is great! I tried other accesses.
I held down the #3 button when turning on the radio power. I got a decimal number like "1.08257 1M" Does anyone know what this is? what happens if it is changed?
irenesbob
A6 (C7 Platform) Discussion
27
06-23-2016 04:44 AM
BongoCruiser
12-15-2009 06:46 PM
Edwards944
09-29-2004 03:56 PM
Edwards944
02-18-2004 07:19 AM
ECF
10-26-2002 08:48 AM
Quick Reply: A6 Symphony Hidden EQ settings
