Coolant sensor inhibit start Yes or No?
Old 09-10-2013, 09:35 AM
LakeTahoeQuattro's Avatar
Default Coolant sensor inhibit start Yes or No?
Can the coolant sensor that installs behind the engine inhibit a 2.7 from starting? Is there a way to test this sensor to see if it is good or bad before installing a new one.
Also, other members have confirmed that o2 sensors are not required to start the engine. This is correct?
Old 09-10-2013, 06:15 PM
odoboyusa's Avatar
As far as I know, the crankshaft position sensor (CPS or rpm sensor) is the only one who will not allow the engine to start.
Do you have icms on your car? I've seen people having issues with starting when the icm plugs were crossed, one icm should have the black plugs and one should have the brown ones.
Old 09-10-2013, 07:39 PM
lucio_liu's Avatar
if you mean coolant temp sensor, the litter green things under the intake pipe. NO, it does not affect starting
Old 09-11-2013, 02:53 AM
Tech Guru
4Driver4's Avatar
Yes. No. Yes.
eggsngrits
12-08-2021 06:58 PM
Speec
10-06-2015 07:30 PM
9552T500
09-08-2015 05:41 AM
PoisonBeef
09-04-2015 05:29 AM
ECS Tuning-Audi
09-03-2015 12:45 PM
Quick Reply: Coolant sensor inhibit start Yes or No?
