Alternator/ power issue?
#11
A 2000 model will have the immobiliser in the dash.
Immo 2 yes - from 1997 to 2004 on the A6.
The fact that you've had it running and now it's quit and you have a multitude of dash problems, your problem is the dash.
Sort out why the dash is giving you grief, and the immobiliser will sort itself out...
VCDS connection problem, I'm not sure. But I think everything ODBII goes via the ECU (don't know for sure, just a bit of logic).
As you said VCDS lite, I'm assuming you have a generic cable? These can have touch and go connection issues I've found. Also, the ECUs on these cars are slow (These ECUs are mid 90's designs custom made to do a simple task (for a computer anyway!), so they're not even as advanced as a mid 90's PC), so give it some time...
#12
All sounds logical.
I just bit the bullet and bought a full VCDS cable so hoping for some better results in a couple of weeks when it ships from the states to the UK.
Thinking the lack of connection might be due to low power in the battery and jump batteries so maybe jump from my car with the engine running to see if we get power to the control modules.
So plan is to try and get to all connectors on the dash and reseat them before trying to get connected with vcds to see what codes show up.
#15
ok so spent a couple of hours at the car tonight.
Swapped in a new battery, ran the car via jump cables to my other a4 to keep the battery charged whilst checking things.
- left battery disconnected for 20 minutes
Findings:
- Reseated the two cables on the cluster - no change
- Reseated the two cables on the ECU - no change
- checked all fuses - all look fine
Plugged in a real vcds cable and managed to get some scans out although nothing from the cluster or engine
Took a few pics and below is the scan log.
The cluster code is 4B0920950D and only had two cables attached (green & blue). There was a much smaller black connector but I could find no cables hanging free behind the cluster?!
Annoyingly there are no clusters on ebay for the same code - would another model work such as the three connector versions? any idea of codes?
Question now is do you think it is the cluster being duff or does the lack of connectivity to the engine module suggest more issues?
Also would the flickering power to the cluster suggest a duff cluster or a bad connection or ground somewhere?
Where do the other end of the cluster connectors go to so I can try reseating them at the other end?
Saturday,10,January,2015,20:10:37:44381
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
Chassis Type: 4B - A6 C5 2000
Scan: 01 02 03 06 08 16 17 18 22 34 35 36 37 45 55 56 57 65 67 75
76 77
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C37E34C8C069AC1933-5140
No fault code found.
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 H
Component: A6-Klimavollautomat D64
Coding: 00041
Shop #: WSC 02325
VCID: 1F4DD4409D1081D9761-25A6
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
01582 - Signal for Coolant Temperature
30-00 - Open or Short to Plus
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 H
Component: Central Lock/Alarm D33
Coding: 04814
Shop #: WSC 02325
VCID: 2E533984EABA1851CD7-4EE8
6 Faults Found:
01561 - Rear left door
59-10 - Can't Unlock - Intermittent
01562 - Rear right door
59-00 - Can't Unlock
01559 - Drivers Door
60-00 - Won't Safe
61-00 - Won't De-Safe
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00002
Shop #: WSC 02325
VCID: 60CF97BCE0EEFE210FB-4B4C
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186 E
Component: Radio 0001
Coding: 00203
Shop #: WSC 02325
VCID: 224BDDB4AE62AC3159F-4B00
Address 76: Park Assist Labels: 4B0-919-283.lbl
Part No: 4B0 919 283
Component: Parkingsystem A6 RDW D18
Coding: 00116
Shop #: WSC 02325
VCID: 66C381A402CA9011F57-51F2
3 Faults Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
31-00 - Open or Short to Ground
01548 - Sensor for Parking Aid; Rear Right (G206)
End-------------------------(Elapsed Time: 05:17)--------------------------
Findings:
76 77
Shop #: BB 24334
Coding: 00041
Shop #: WSC 02325
2 Faults Found:
Coding: 04814
Shop #: WSC 02325
6 Faults Found:
60-00 - Won't Safe
Coding: 00002
Shop #: WSC 02325
Coding: 00203
Shop #: WSC 02325
Coding: 00116
Shop #: WSC 02325
3 Faults Found:
#17
Bit of reading and I think I have a cluster v1 and a half - digital clocks but only two connecters!
Testing the vcds cable said no can bus
Immobiliser light is flashing - do we think this might be v1 or v2 immo?
#19
looks like it is the cluster!
tried a working diesel cluster and the power appears fine - no flashing, reseting tests etc.
On email at the moment to send off the cluster for repair...
Lucas Larson
02-27-2020 09:37 AM
20VT90q
08-25-2008 01:56 PM
Thom
03-18-2004 09:35 AM
TwnTrbo
07-02-2003 08:17 AM
