Any A6 2.8 no start gurus want to scratch thier heads?
#11
"low current wire to starter "
this was the first thing i thought of actually ...
when you go to "start " position on the key does the actuating wire for the starter solenoid give you 12v ..
i had this EXACT issue. on mine i found that i read about 11.75 so thought that was okay so moved on . As it turns out that wire was completely coroded about 12 inches up iside the insulation .. after about 12 inches i had clean wire so i soldered in a new piece with a new connector on the end .. Boom the thing started ...
My old Audi 90 had issues with the ignition switch but that was more just accesories not working.
Good luck
Good luck
The clue is most obvious when he said that during a jump it starts.
Here is my answer, the load reduction relay directs as much battery current to the starter by opening the main bus contact to other current loads when the key switch is in the start position and when released the power is back to the other loads, this is why the car will not start with one battery, now it is possible that the one or more of the 5 ignition switch contacts are weak too like the one going to the relay or the relay is bad.
We can't go on a park position safety switch or a clutch engagement switch, that wouldn't be logical if it starts with battery jump, not that you or anyone else mentioned this.
Just drawing down conclusions.
#12
I think the OP covered that on his post#5.
#13
i just had a though about this ...
Op did no say HOW he jumpered it in the engine bay. did he do both posts of the battery , or one post of the battery and a ground some place.
could it still not be the ground starp from the battery to the car ? if he puts positive jumper cable on the battery and negative to a solid ground point , he has bypassed the original car connection from battery to the body on the negative side .
just musing..
just musing..
#15
just musing..
just musing..
#17
vicnorman
17
02-28-2015 06:02 PM
ayap
08-03-2011 04:08 AM
