AUDI A6 2002 LOST KEYS
Old 12-19-2014, 04:11 AM
Eddy Dar's Avatar
Default AUDI A6 2002 LOST KEYS
Help Ive lost both of my keys for my audi a6, what do i do now apart from cry!!!
2002 02 avant 1.9 tdi engine code avx
Old 12-19-2014, 04:22 AM
raj99's Avatar
Contact your local dealer who should be able to assist. Or a locksmith with expertise in VAG vehicles. Either way you'll need to pay.
Old 12-19-2014, 05:53 AM
N_Jay's Avatar
If you have had it a while start looking for the Valet key.
Old 12-19-2014, 06:10 AM
SloopJohnB@mac.com's Avatar
Default Normally that disqualifies you from Audi operation.
But with your VIN and registration an Audi dealer should be able to make a set of keys.
BOHICA
Old 12-19-2014, 06:20 AM
jcman's Avatar
Sounds like a dealer visit as mentioned. Just curious on that engine code, maybe a AWX or AVF?
Old 12-20-2014, 11:19 PM
Eddy Dar's Avatar
How much am i looking at, i don't think i ever had a valet key, and yes i got the engine code wrong.
Old 01-06-2015, 04:38 AM
Eddy Dar's Avatar
Default update to lost keys
Hi,
UPDATE!!!!
I'm reluctant to go to stealers. But I have done a bit of research and have found out the following:
1. Luckily i left the doors open so If I can get the door lock out & to a locksmith I can get a laser key cut. Does anyone know how to remove door handle/lock. I've replaced the window cable before so am familiar with removing the door card etc.
2. Ive bought some 2nd hand keys wit the same code (ending 0231A) Im told that these can be programmed to my car, how do I do this ?
3. Then the key/s need adapting or reprogrammed to the car. For this I now have VAGCOM but need the immobiliser pin. I don't want to go to the dealer but was wondering if anyone knows how I can get the PIN. VAGCOM will not retrieve this is I'm led to believe.
Old 01-06-2015, 02:10 PM
seishuku's Avatar
I used a program called "VAG EEPROM Programmer" to get my PIN from the cluster, should be able to find a download with a Google search.
VAG Commander will work too, seems to be a bit flaky at times though.
Old 01-07-2015, 03:38 AM
Eddy Dar's Avatar
How easy is it to use VAG eprom programmer to obtain the PIN. This is not for the cluster its for the immobiliser.
Old 01-07-2015, 09:14 AM
seishuku's Avatar
The cluster is the immobilizer, though some cars it is a separate module... Not the 02 a6 though.
Its easy, just connect with a KKL cable, read the eeprom from the cluster, the program will tell you right in the window.
Quick Reply: AUDI A6 2002 LOST KEYS
