PaJames's project.
Old 02-18-2010, 04:09 PM
PaJames's Avatar
Default PaJames's project.
OK so here is some info on the car in question.
2002 A6 3.0 tip quattro. Red with black leather.
I scanned this car with my Vag-Com. had a few engine codes, and 14 alarm codes....I cleared them to see what ones came back, Only one did.I have to order the bentlys, I know, I know, what are ya waitin for... But here is where im at for right now.
01592 Air Quality Sensor G-238, 57-00 electric circut failure
Just what does this sensor do? and where is it located?
Question 2- I turn on the flashers/hazard's, everything works as it should. I use the turn signal, left or right, solid no flash for directionals. do the directionals, and flashers/hazard lights work off one flasher? Or are they seperate wiring?
Question 3- What radio removal tool do I need for the symphony2? is it the pointed (knife blade) keys? or the ones with the T end??
Thank you in advance, James K.
Old 02-19-2010, 03:48 AM
NJA642's Avatar
Default Answer to #3
http://www.weschan.com/audinav/
(first hit in bing for "remove symphony II")
Old 02-20-2010, 06:01 PM
rs4tech's Avatar
air quality sensor is for the automatic recirulation feature of the climate control. the sensor is located just below the pollen filter
the turn signal problem is caused by the hazard switch. the hazard switch contains the turn signal relay so you have to replace the whole switch which is easy. just pop off the trim around the switch(be careful not to break off the 6 metal clips) and pull the sensor out with either 2 small screwdrivers or pick tools
the radio removal tool would be the knife edge tool
Old 02-22-2010, 04:29 PM
PaJames's Avatar
Default 2 of 3 done
got a new hazard switch today, installed it and cured the problem. But before doing that I installed the refurb. radio I bought from ECS. Figured the radio was out made for more room to get to the trim, all 6 clips still like new..got lucky I guess.
Going to get a new cabin filter tomm. and will see if that has anything todo with the other code..
this is just the start, Thanks again guys...
Audi newbie..James...
04A41.8T_CVT
VAG-COM Discussion
02-19-2008 07:12 AM
yanbu
05-17-2007 10:37 AM
rayleung
VAG-COM Discussion
07-29-2003 10:14 AM
lunamar
06-22-2003 08:59 AM
fred_austn
08-14-2001 10:40 PM
Quick Reply: PaJames's project.
