Audi a6 c5 1.8T 20v Big problem
Old 02-19-2017, 06:12 AM
  #11
exerilok's Avatar
Ok, but but oil level is to max, new oil and filter.. I hope mechanic didnt overfill it with oil
Old 02-20-2017, 08:27 AM
  #12
tester123's Avatar
You didn't check it like I mentioned?
Check/change oil pressure sensor.
Old 02-20-2017, 02:48 PM
  #13
twowheeldrive's Avatar
as you could see cabels are in very bad condition
Old 02-20-2017, 04:42 PM
  #14
Harleyguy's Avatar
Care to elaborate???
Old 02-21-2017, 12:54 AM
  #15
tester123's Avatar
"twowheeldrive"..... you replied to wrong thread?
Old 02-21-2017, 04:38 AM
  #16
exerilok's Avatar
im gonna check it now.. I didnt drive car much last days.. Now im gonna drive it 15 min, 10 min parked, and then check
Old 02-21-2017, 05:28 AM
  #17
exerilok's Avatar
oil is on max. but funny thing, it smells like gas, bensin ... weird
Old 02-21-2017, 06:22 AM
  #18
tester123's Avatar
Can you locate oil pressure sensor and see its condition / wiring? If you see oil in the electrical connector, it is dead for sure.
Old 02-21-2017, 06:48 AM
  #19
exerilok's Avatar
I dont know where is it?? can you tell me where is it located in 1.8 T ? Im noob with cars ...
Old 02-21-2017, 07:13 AM
  #20
johnkk's Avatar
Assuming it's the same as other 1.8 and 2.0 engines, it's on the bottom of oil pan. Make sure you order real OEM, for both pressure and level. Meyle not both.
Now you get to drain the oil again. Why your tech didn't check/replace the sensor when he dropped the pan does not make sense???
Quick Reply: Audi a6 c5 1.8T 20v Big problem
