Audi A6 Service interval Questions.
Hello,
I have some questions regarding the audi A6. I'm doing an exercise for my college. And I'm learning to be a car mechanic. One of my exercises is that I'll have to make a forum post on a technical website and I thought this was one of the best. The exercise is about diagnose devices like the snap-on modis. The question is a 2 part question basicly.
1 How do i reset the service interval on an Audi A6?
- With the diagnostic device?
- And manually withouth any special equipment?
Thanks for your efforts,
Maarten Veldhuizen
Ps. Don't blame me for not searching the forum. I had to make a forum post for the exercise:P.
Maarten Veldhuizen
AudiWorld Expert
Yes, it can be done with and without a diagnostic device. A VAG COM cable with applicable software is the easiest method. Here are the steps to reset the service reminder indicator (SRI) without using VAG Tool:
- Switch ignition off.
- Press and hold down reset button for trip odometer in instrument cluster.
- Switch ignition on while button is pressed down. "Service OIL" appears in the display of the trip odometer.
- Release button.
- Pull setting **** for time in instrument cluster until "Service OIL" indication is reset. "- - -" appears in display.
- Press reset button for trip odometer again, to advance to next service event.
- Release button. "Service INSP" appears in display.
- Pull setting **** for time until "Service INSP" indication is reset. "- - -" appears in display.
Is there a method like this for a 2006 A6?
- Release button.
- Release button.
have you tried this on your 2006?
Have you even read your owner's manual?
I don't own a 2006, and no I haven't tried it yet on my 2001.
I refer to my owner's manual quite often, and there's very little advanced DIY info in it, so I assumed this procedure isn't there either. I'll take a look, and if it's in there, my apologies for the erroneous assumption.
Thanks. ISATI, apparently, since I only use the threaded view and am not interested in setting up my responses so they can be viewed correctly in other views...if they can at all.
