Auxillary fan constantly running?
My auxillary fan turns on right after I start the car. It often will cycle on and off every few seconds, but other times it will just stay continuously on while the car is running. This started happenning about 5 months ago. A search revealed the culprit may be the auxillary fan control module. Has anyone else had this experience? Does a faulty control module seem reasonable? VAG scan revealed no codes. Finally, where is this control module located? Thanks in advance.
Paul
Paul
That's the short answer. The slightly longer one is:
Yes it does...SO, if it's always running when the AC is switched on and sounds like an air-raid siren, yes, it's probably the fan control module. Normally, they fail because the main electric fan jams and the control module blows to "protect" the fan. When the module is faulty, the system commands the aux fan to HIGH all the time when AC is enabled. The main fan normally gets jammed by a piece of it's own trim, which can be easily removed.
If the aux fan is ALWAYS ON - regardless of the AC being on or off, the module may not be the cause.
The module can be purchased at your favorite parts supplier and is a 50% bitch to replace unless you go service position. From there, it's a 10 minute job. Yes, I've replaced mine to solve the problem described in paragraph two.
Thanks for the detailed reply. I really appreciate it. The auxillary fan will go off when the a/c is turned off, however the auxillary fan goes on the minute I start the car regardless of coolant temperature so long as the a/c is on. In the past I've heard it go on very rarely on a hot day. Now it is on all the time. I know this is not how it is supposed to be. Thanks for the tips. I will look more closely at the fan to see if it"s jammed.
Paul
Paul
Yes, the aux fan does go off when econ button is engaged. Does that suggest the Control Module still may be the culprit of it running non-stop? It is my understanding that when the a/c is on the auxillary fan should come on as needed and not be on the entire time the car is running. Do I have that right? Thanks.
Paul
Paul
Paul
Paul
Grab hold of the blade of the back-side fan (with the car OFF, of course). If it will not spin freely when applying finger pressure, it also has probably "failed in the normal manner" and is jammed up by a small piece of rubber trim stock that has slipped. Find the jam, remove it, assure a free spinning blade and the fan is PROBABLY still good. Historically, the control module will fail and "protect" the fan (although I'm sure it can also fail WITHOUT the fan being jammed).
You can then decide to replace the control module or not. It took me one entire season to get around to it and then I only changed it because I took the whole damn thing apart to replace a failed alternator and the old one was right there, mocking me. If you don't use the AC a lot in your environment, the only thing that's being hurt, AFAIK, by the aux fan running full speed is the ears of you and everyone around you
Yes - you have that correct. It SOUNDS like the fan control module has failed in the "normal" way.
Grab hold of the blade of the back-side fan (with the car OFF, of course). If it will not spin freely when applying finger pressure, it also has probably "failed in the normal manner" and is jammed up by a small piece of rubber trim stock that has slipped. Find the jam, remove it, assure a free spinning blade and the fan is PROBABLY still good. Historically, the control module fails to "protect" the fan (although I'm sure it can also fail WITHOUT the fan being jammed).
Paul
Same on 2003 A6 2.7
I'm seeing the same thing on my '03 A6 2.7.
Aux fan is on full speed when AC is on 'Auto' but occasionally cycles off then back on.
Turn on 'Econ' mode then aux fan stops.
It does not matter what outside temp is or temp of engine.
It did it this morning at 50 deg and a cold start.
Does anyone know the part number for this unit?
Thanks.
Thanks.
