Blauparts Brakes/Rotors question...
Been away for a while... I hope everyone is doing well here.
Quick question. Need to replace front rotors / pads on my '01 4.2. Last time got Meyle (I think)... anyway, looking at Blauparts' U-slot and regular rotors / pads packages...
Are those U-slots worth the extra cost? Some have mentioned vibration after a while or even worse, immediately. Please share your experiences / thoughts.
Thanks!
Thanks!
Thanks!
Thanks!
Think I'll stick with aftermarket OE type for now... but just curious if anyone had experience with blauparts rotors.... that's what I wanted to know.
No, they are in a bad shape and I feel its just easier to replace them with new ones while I have everything open rather than to mess with old rotors new pads, seating/bedding issues etc.
I really like the EBC Ultimax Slotted rotors and so I think the U-slot might be better than the regular version?
Not sure about the 4.2 but I had to measure the rear rotor hat for the right replacement (I used paper instead of measuring without the wheel). For some reason my option code sticker doesn't show whether I have 0N5 (1.75" offset) or 0N6 (1.50" offset)...
Well, here is an update:
I got the pads/rotors from Blauparts and was surprised that they sent Textar (supposed to be OE Audi/MB uses?) pads along with their "HCC or High Carbon Chromium" (supposed to be higher carbon content and perform better...[we'll see down the road]). In any event, the rotors and pads (8 pad setup) are perfect fit and had no issues during install.
A quick road/brake test was a positive experience. The brakes are very effective and able to stop the car without any issues. Moreover, the brake "feel" is very good and "predictive".
Overall, I'd give them a very good rating right now. Will have to see how they hold up after some mileage.
Textar is a good choice.
Seriously? I guess I don't have that kinda luck for brakes... For one, the fat guide pin (in the middle) on passenger rotor rusted and stuck so that froze the carrier and caused all sorts of issues. Replaced pads and rotors (Zimmermans -I think). That lasted for a while and wore out that I changed pads and rotors again (not enough meat to resurface). Then went with Zimmermans and Pagid pads. During spring, didn't drive for a week or so and rust buildup -which went away but must have glazed the pads or something because braking caused severe vibration and I mean severe like the bearing lost a marble. Replaced them now with HCC from blauparts. Almost all the vibration went away immediately but the rears were also shot. So, went a different route this time with Wagner. Yeah, wagner from AdvancedAuto! along with Wagner's Themoquiet pads. Basically that's wagners top of line pads. Contemplated Pillengis and textars but saved over $130. Flushed the brake fluid completely including reservoir. The brakes are so good now it feels like a new car! LOL Lets see how they hold up.
Before I did my front brakes, I contemplated Wagner (the best quality ones) since they had mostly favorable reviews. I ended up going with them however since they had to be ordered as well and were not stocked. Also, I cannot comment on the overall quality of the many aftermarket pads, but I can say that the ones I got from Audi were incredibly heavy duty compared to the POS ones the PO put on from some no name autoparts store. He then proceeded to leave the anti rattle springs off the front calipers because those pads he got didn't have the clip on the outside to fit them. For the longest time I thought I had to redo my recent control arm refresh but it turned out to be my brake pads literally bouncing back and forth in the calipers.
