Bolt fell in transmission...
#11
I read a lot of posts to get ideas of what types of things happen to each of the models etc. Gives me a good idea of what to avoid/desire etc.
As I am unknowing, is there a hole in the top of the bell housing that allows a bolt to fall in?
#12
This side shows the oval hole above the sensor, not sure about the other side.
#13
So, my dumb question for the day. Why is there a hole? Seems like it is an invitation for accidents like this. What is the purpose for this hole?
#15
I don't know about C5 trannies, but on a Mk4 Jetta there is a hole for true TDC and it's at the top of the tranny where it connects to the engine, but it is usually plugged up by a plastic cap...
#16
??? The oval holes are for prying the TC loose from the flex plate
IIRC the TC comes out with the transmission; you unbolt the TC from the flex plate and pull the tranny/tc out…you use a special tool or a universal strap to hold the TC onto the transmission input shaft when removing the transmission assembly. Audi Bracket 30-211 A holds the tc in the trans.
#17
uble1234
14
10-23-2020 08:07 PM
