Brake line screw up...
Hello Forum, it's been a while...
Tried to change the "flexible" brake hose (rubber sleeve torn from abuse during brake jobs / pad & rotor changes etc.) which is not leaking but won't pass inspection.
The issue is that when trying to loosen the nut for brake line, the entire line was turning/twisting... PBlaster etc. even then it's not moving. It moved a little because now I have fluid leaking out like crazy but rubber hose part won't turn.
Does it mean I need a new line? Perhaps, the question I should ask is, if that nut/end fitting of brake line goes, what repair(s) can be done ? Or, the line needs to be replaced?
Had same problem on my S6 but used a propane torch
Thank you SloopJohnB. Ended up having the "experts" at midas fix it -rather butcher and splice it to extend and put new fitting. Not what I wanted to do but had no choice with my current living situation.
OK. Save your receipt for when it leaks.
Those double flared or bubble flare brake line ends are tricky. I trust they used a decent brake line rather than copper tubing!!!
Howard Kim
12-22-1998 03:31 PM
jfl
10-26-1998 04:43 AM
