Brake Warning light
Brake Warning light
I just replaced the brakes on my 2000 A6 and now I have the Amber brake symbol as well as a flashing red Brake light. The fluid level is correct and all seems fine with the brakes working. Any suggestions on what could be this problem?
Maintenance Induced Error.
If you pushed old brake fluid up the pipe to the ABS rather than bleeding the old fluid out of the caliper bleeder when you pushed the pistons back to install thicker new pads, it's possible the ABS system got crap in it and is hollering at you. If you broke the cap wire on the brake fluid sensor or the float isn't, the fluid level won't transmit and the red brake light will stay on.
SouthShoreS4
11-21-2006 02:09 PM
R32Mathieu
08-09-2004 12:20 PM
