brand new coolant tank from dealer still leaking
Hey audi world so this weekend I spent $55 on a brand new dealer coolant tank and to my surprise the damn thing is still leaking at the connection from the upper radiator hose (little hose near the cap) it's so frustrating because it leaves a mess on my plastic engine cover and causes hecka steam also after driving. I don't know what to do anymore I have pushed the hose as far as possible the hose itself is new and I tightened the worm gear clamp and nothing. At first I thought I was the cheap aftermarket tank I had but that's not the case. What else can I do? I'll try to post a pic later if necessary.
Thanks
2001 Audi A6 2.8 Avant quattro 185,856 miles
Thanks
Frustrated with this...
Thanks
the hose I put on is a 3/8 size and it doesn't slip on or off easily it's actually snug. I have buddy who drives a B5 A4 1.8T that is manager at one of the oreileys auto parts here in town that guided me on the hose purchase. But just to be sure what is the proper size?
I don't know the proper size, but a hose that is just a tad big will sometimes pinch and leak when tightened, (sometimes when over tightened).
Small worm clamps can also pinch and cause a leak because the pull in at one spot, not evenly.
I'm very tempted to put the original Audi clamp back on since I still have it and see what happens. I noticed the other day that if I put just enough force the worm clamp can be moved around (spun) even if it's "tight"
you should probably use a fuel line hose clamp. if you can turn the hose it will leak in that application as it is under pressure.. turn means no good seal . .
hmmm I'm going to give it a shot with those clamps you mentioned. Should I go ahead and replace the hose again while I'm at it?
If this was happening to me I'd take the part back to dealership and get a new one, it just sounds like something else is causing the leak.
You sure the cap isn't leaking? They do go bad
