Caliper Interchange for 1999 & 2001 A6 quattro
I'm looking for a new set of rear calipers for my 1999 A6 quattro. I presently have 237,000 miles on the odometer, so I'm not looking to spend $250 per caliber on a new set.
I found a pair online for a 2001 A6 parts car. The part number listed is 8E0615424. When I called my local Audi dealer I was told the part number for my car is 8E0615424A. Can someone tell me if the "A" at the is specifically for the quattro model or if these parts are interchangeable?
Thanks AudiWorld!
Thanks AudiWorld!
I've looked at the pics online and they appear interchangeable.
Thanks AudiWorld!
Thanks AudiWorld!
Re: Why Not Rebuild vs. buy replacement
When I went to have my brake fluid flushed my mechanic was unable to because the bleeder screws had rusted and he told me he hadn't had any luck drilling them out and re-tapping the screw. He advised me to get a new set from RockAuto or comparable.
Yep...bad luck
When or if you get new calipers use antiseize on the threads and flush your brake system annually, especially in salt-using states. USE the little rubber bleeder cap too.
The part number without "A" is Not interchangeable
I called Audi in Plano, TX (where my car originated) & spoke with someone in the parts department, who told me the part number without the "A" on the end was the part number for an A4 ('98-04, I believe). I agree the parts look identical. My search goes on.
So in the meantime no car?
Just because it's for an A4 doesn't meant it won't interchange to the A6. All things being equal, I'd try the A. How much are you risking? $50? LOL.
Re: In the Meantime
Car is (was) still drivable. I was just wanting to change the break fluid for the first time since 2005 (and 185,000 miles). The bleeder screws are rusted I've found an OEM rebuild for $80.
Now the right front brake is making noises that aren't normal (see my latest post).
Audi A6 F/S 2001 A6 S-line Quattro 2.7T
JohnTerri
07-03-2015 12:21 PM
Drew Leask
03-22-2015 09:23 AM
PINK PANTHER 2.7T
03-17-2006 04:10 PM
