Camshaft Position Sensor (G40) 3.0 AVK Engine. HELP
#11
Bro, you are my savior.
Would it it be possible if you could share the PDF from the Bentley manual if you don't mind.
Like you said, the sensors are locate it underneath the mas air flow. Passenger side, there are two, and this engine has 4. Now, which one is 1 and which one is two? The top being number one and the bottom as number two? As for me I went the g40 is on the top. I will provide pictures today.
Also, the sensors only have one Allen bolt and no more. Not sure where do you get 6 bolts from.
Please let me know your input thank you so much!
The G40 is listed as the intake cam sensor, so it will be on the intake manifold(inner) side of the head. I suppose this is what you mean by top since the head slopes. Exhaust would be on the outer side, where the exhaust manifold is leading to downpipes. Keen grasp of obvious.
