Camshaft skipped during valve cover gasket
Camshaft skipped during cam seal replacement
Im in the middle of valve cover gasket replacement and was following a guide to replace the cam seals. I was trying to loosen the bolt behind the camshaft sensor, while i was holding it with some pliers, but it moved and now flat end on camshaft is now facing downwards. im afraid that this will mess anything up. Both flat ends on shafts were facing each other inwards, and now the right side(passengers side) which im working on flat end is facing downwards.
Is there any way to straighten this up? What if I now change my drill to turn the shaft counterclockwise? will it move it and align to were it was at before
Osmosis
10
08-01-2016 09:25 AM
4ringsinutah
04-20-2016 09:20 AM
nickcarguy
10
04-09-2016 07:20 PM
hunterp27
18
03-31-2016 06:12 AM
