Can a rebuilt CV axle assembly cause vibration? - AudiWorld Forums
Old 03-02-2008, 03:10 PM   #1
Default Can a rebuilt CV axle assembly cause vibration?
my car had a noticeable vibration when accelerating from low speed or accelerating from around 60 to 80. Also noticeable when climbing a slope, rather than just cruising at a constant speed.
This all occured right after my front passenger side CV axle assembly replacement. I checked for loose bolts and even tried another set of wheels/tires to verify that it wasn't a bent wheel or unbalanced wheel.
so, caan a rebuilt CV axle assembly cause vibration? Anyone had this kind of issue?
vunu is offline   Reply With Quote
Old 03-02-2008, 04:40 PM   #2
It can - wasn't rebuilt proper, not enough grease in boot or it could be slightly out - not true
Reifle is offline   Reply With Quote
Old 03-02-2008, 07:58 PM   #3
socalclimber's Avatar
Default Yes - seen this in worn/bad inner CVs
I once had a VW with similar symptoms, vibration or shudder on acceleration, esp. hard acceration. It was a bad inner CV. Take car back to shop. Not all rebuilt axles are equal, some can be basic clean-up jobs (cleaned, painted, tested). Was this an audi OEM rebuilt axle?
socalclimber is offline   Reply With Quote
Old 03-03-2008, 04:43 AM   #4
Default Several possibilities:
1. defective CV
2. improper fit causing it to kink ( seen this)
3. inner bolts improperly seated / torqued
4. Wheel improperly seated on hub ( nothign o do with CV)
others I'm sure.
Grant
Just Me is offline   Reply With Quote
Old 03-03-2008, 05:45 AM   #5
If it's under acceleration/load, then I'd say the CV is shot...BTDT on a friends allroad.
absolutcq20v is offline   Reply With Quote
Old 04-19-2010, 08:50 AM   #6
we normally replace the axle assembly with a rebuilt unit.. sometimes improper installation can cause vibration..try to check your repair manual it will show you the diagram about axle replacement.
jking is offline   Reply With Quote
Old 04-19-2010, 10:21 AM   #7
Sure, but dont jump to conclusions.
Its good that you checked wheels/tires - the #1 source, even when people swear they are fine.
But also consider:
- drive-shaft bolted in slightly crooked
- center/prop shaft bearing or out of balance
- drive-shaft out of balance ( would have to be a lot since it is such small diameter...)
But certainly, if there is play in the races, it can either go around eccentrically, or, worse, get out of alignment and bind.
G
Thread Thread Starter Forum Replies Last Post
2002 A4 3.0 quattro variable length intake manifold broken levansula A4 (B6 Platform) Discussion 20 08-02-2016 07:11 AM
Sluggish Performance Solved - Replaced Intake Manifold Links Galco A8 / S8 (D3 Platform) Discussion 15 10-19-2015 04:56 AM
Allroad "double spoke" wheels/vibration Tahoesilvers4 Audi allroad 3 09-29-2015 08:05 AM
:: ECS Tuning :: Assembled By ECS Service Kits ECS Tuning-Audi Vendor Showroom 0 09-25-2015 09:30 AM
:: ECS Tuning :: B7 A4 2.0T ECS RA4 Conversion Clutch Kits ECS Tuning-Audi A4 (B7 Platform) Discussion 0 09-24-2015 01:06 PM
Tags
a4, a6, accelerating, audi, axel, axle, axles, bent, cv, forum, install, rebuilt, sienna, unbalanced, vibration
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
