Can toe-in for the back tires be adjusted on the A6 - AudiWorld Forums
Old 01-07-2010, 10:36 AM   #1
Default Can toe-in for the back tires be adjusted on the A6
Or only the camber. I just bought new tires and I want to make sure the front and rear alignment is correct. Looks like I might have some funny ware on the back tires, or th etire could just be junk....
old96A4 is offline   Reply With Quote
Old 01-07-2010, 10:54 AM   #2
AFAIK both the rear wheel toe and camber are adustable.
Toe is set by the eccentric bolt at the inboard end of the tie rod which bolts to the rear subframe right above the inboard rear lower control arm bushing.
Camber is set via the eccentric bolt at the outboard end of the lower control arm which bolts to the bottom of the rear wheel hub.
monkeytronic is offline   Reply With Quote
Old 01-07-2010, 07:52 PM   #3
Hmmmmm, not seeing what you mean , any pictures any where??
I get the camber, don't see the toe in. is it like the A4 wituh the rear control arm?? I didn't see one last time I was under there?? I thought is was fixed toe in . maybe that's why I burn up tires so fast.
Old 01-08-2010, 04:17 AM   #4
Tech Guru
4Driver4's Avatar
monkeytronic is correct. Toe is adjustable. Look from the rear and follow the tie rods up to the point where they attach to the subframe. That's your adjustment point.
4Driver4 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
:: ECS Tuning :: Brushed Aluminum Power Seat Switches By ECS ECS Tuning-Audi Q5/SQ5 MKI (8R) Discussion 9 02-16-2017 12:55 PM
MMI Car button Doesn't work 2004 audi a8l hellonwheels33 A8 / S8 (D3 Platform) Discussion 27 09-02-2016 01:29 AM
Recently picked up a 2014 Q5 Dudealicious Q5/SQ5 MKI (8R) Discussion 7 09-12-2015 04:51 PM
Adjust passanger seat from driver side fkaufman A7 4 09-07-2015 08:59 PM
95 Cabriolet Wheel Alignment Issues. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-02-2015 09:48 AM
Tags
200, 2000, a4, a6, adjust, adjusting, adjustment, alignment, audi, awd, b6, fronttrak, quattro, rear, toe, toein
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
