Coolant leaking by drivers side - AudiWorld Forums
Old 04-12-2010, 03:04 PM   #1
Default Coolant leaking by drivers side
I have had a slow coolant leak for a while. But recently it has been leaking faster. Where I was only adding coolant every 2 weeks its now every 2 days.
I cannot pinpoint where it is coming from but the coolant is dripping down the drivers side of the trasmission right behind the engine.
Any ideas? I thought it may be the aux coolant pump but all the write ups I am reading are saying that leak shows up on the passenger side.
ucf_motorcycle is offline   Reply With Quote
Old 04-12-2010, 04:01 PM   #2
Interesting. Im diagnosing a coolant leak on the drivers side as well but mine drips on the front of the motor. You may also want to check the front too as it may be getting blown back towards the trans or traveling towards the back on something. I haven't figured mine out yet.
catch2otwo is offline   Reply With Quote
Old 04-12-2010, 04:05 PM   #3
Tech Guru
4Driver4's Avatar
Aux coolant pump.
4Driver4 is online now   Reply With Quote
Old 04-12-2010, 04:09 PM   #4
Quote:
Originally Posted by 4Driver4 View Post
Aux coolant pump.
x2.... unless you unluckily have broken turbo coolant line (obviously only the 2.7t /rs6)
2.7Lturbo is offline   Reply With Quote
Old 04-12-2010, 05:12 PM   #5
On the 2.7t, you can aim a small flashlight through the thicket of stuff at the front of the engine and see a tiny bit of the top. If there's any pink, it's the aux pump.
There's good instructions here somewhere. Not a particularly hard job, but a lot of dis/reconnection--a little labelling and good organization helps. And you'll wonder what German engineer put such a failure-prone pump in there!
rocketman4321 is offline   Reply With Quote
Old 04-12-2010, 06:24 PM   #6
mine is a 2.8, what goes wrong with the pump causing it to leak?
Old 04-12-2010, 06:25 PM   #7
Well I'll take a look and try to see it again. But I think I will go ahead an order that aux pump. I don't think I have ever heard the aux pump running so I think its broken anyway.
Old 04-12-2010, 07:09 PM   #8
Tech Guru
4Driver4's Avatar
Nothing on the 2.8. They are in a different location and they don't leak.
On the 2.7 the plastic cracks.
Old 04-12-2010, 07:10 PM   #9
Tech Guru
4Driver4's Avatar
I doubt you'll hear it even if you replace it. It rarely gets hot enough for that pump to run.
Old 04-14-2010, 11:41 AM   #10
unless you do the s4 mod and switch the activatio switch to a lower temperature , then it runs like a built in turbo timer
Thread Thread Starter Forum Replies Last Post
EPC Light on... Coolant Leak ... ECM needs Replacing Audifastdaddy A8 / S8 (D4 Platform) Discussion 10 07-07-2016 05:43 PM
S8 Brembo crossover pipe leak Optimusglen A8 / S8 (D2 Platform) Discussion 0 09-08-2015 07:57 AM
Just checking to make sure I'm seeing what I think I am. bilbo6209 A6 / S6 (C5 Platform) Discussion 10 09-04-2015 05:07 PM
:: ECS Tuning :: B6/B7 S4 ECS Assembled Heater Core Refresh Kit ECS Tuning-Audi S4 (B6 & B7 Platforms) Discussion 0 09-03-2015 01:45 PM
95 Cabriolet Power Window Issues. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-02-2015 10:02 AM
Tags
1995, 1999, 27, a6, anti, antifreeze, audi, coolant, diagnose, driver, drivers, freeze, leak, leaking, side
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
