CRAP! Camshaft moved?! Possible to figure out TDC again?!
#41
This is unbecoming of an excellent Audi mechanic like yourself! I expected more from you!
Leave the socket to die on its own in a miserable death? Well, I feel strongly about this. Seriously, you gotta find it. Personally, I never lost a part or socket during my T-belt job or any other repair for that matter. Actually, I take pride in the fact that I am still using the same Craftsman tool set bought 20+ years ago! Now, breaking few sockets is another story and that's quite acceptable as Sears replaces them for free.
The only thing I sort of lost was a small plastic clip that was part of the quick connect on the hose for headlight washer pump. I spent a good hour looking for it and finally gave up, put the bumper etc., dropped the car, backed out and there it was on driveway. Pulled the fog light and connected the hose and clipped it. In my book, it was a "job completed to near perfection" (apart from drilling out a bolt at the water pump -snapped head on final torque).
#42
Plus, you forgot to mention the attention to detail (or lack of ) on the work you do. You know it is done right (provided you did it right... ) man, I can't stop. ok, ok, I am confident you are doing a good job. Find that socket! Use one of those flexible things like the ones with claws except there is a magnet at the end. That might do the trick. Also, have someone give you a good kick square in your socket; next time you'll think twice on how to handle a ratchet ....
#43
I wouldn't worry too too much about the cap screw and socket lost in the engine. It will eventually fall out or is somewhere good that you will find it doing something else.
Some places to look for it - under the air intake manifold and then crawl under the car and reach up and feel around on the top of the sub frame. Sometimes things fall onto the subframe and just sit there. Also, sometimes you will see angles you didn't see before and your blind feeling with the magnet will have better results with a new angle...
If it is in the back of the engine though, and on the outside of the engine, you won't cause any real damage as long as you replace the part you dropped.
When I bought my car I actually found a pair of pliers in the engine bay that another mechanic had dropped down there. A couple weeks ago, I found a socket that was wedged into a tight spot that I would have never looked into while I was changing out my axles.
It isn't A-grade work to leave it in there, but sometimes it isn't worth the search when you have bigger fish to fry. And yes, you are doing great so far. You are a fast learner!
#44
I'm busy with classes from 7:45am till almost 8:35pm today so I'm not sure if I'm going to dig into it tonight after a long day when I've got all tomorrow I can work on it. Hopefully I'll make huge progress (finish?!) it tomorrow. I feel like I've reached the bottom of the pit now and it's just replacing and working my way back up to a fully assembled engine. All my parts are here, I don't think I'll run across anything else that needs last minute ordering for this job, I want to get back on the road!
(Haven't removed the cams yet, probably get ready for some freaked out post about a problem with that... :rolls eyes
#46
Apparently up to 2001 where there was a split. I hope you confirmed your VIN with the dealer.
#47
Ya. I've just gone past the rental since I kept adding parts and waiting for them to ship to me, it's $10/day after I think so I'll eat some cost on that end. I overnighted the parts to me initially so I got more time out of the rental since they automatically calculate in like 5 extra days for shipping or something so your 7 days isn't being used up while it's shipping to you.
#48
Nice, the only thing that bothered me was the small fortune of a deposit that they wanted with the tool rental. But... I guess they have to make money somehow if people don't return it. I figure they almost hope people don't return them because they probably make so much money on it. I can't imagine that the set of tools comes anywhere close to $400. But then again, stranger things have happened.
#49
Find that socket! (you might as well just post that you found it because, all my posts will end with that...)
#50
I'm pretty sure I told them my VIN when I called to check if they had the part, I'll see what's up when I dig in there. If not maybe I'll take a trip to the dealer and see if I can swap the part...
