Diminishing (Engine) Returns
Old 07-23-2014, 07:02 AM
  #11
ORKA64.2's Avatar
Originally Posted by SloopJohnB@mac.com
Because you won't be able to get the same engine for less or a parts car/engine for a relative price that may be more desirable to put $ into. Not to mention pulling the engine is more likely to cause other problems with deteriorated wiring, connectors, etc., etc.
If you like the car, repair whatchoo got.
It shouldn't be $4K either…tensioners are available online for much less than stealer price, the plastic shoes are about $22 a pair (you need 4 on a V8), and gaskets, etc. are another couple hundred (spendy Audi stuff).
An independent mechanic should be able to do it for around $2K. A few hundred more if the chains have to be replaced.
It's pretty easy to get my particular car w/ a shot transmission, wrecked and etcetera for even less than the alleged cost of replacing my tensioners (3K). Plus I already put 4K in the engine alone in the past 3 months. But, I am not interested in my engine any more & I'm about 90% sure I'm going to put a built RS6 engine in. Call me "non compose mentis," yo. Thanks for the input though John B Sloop
Old 07-23-2014, 07:10 AM
  #12
ORKA64.2's Avatar
Originally Posted by Airbag
i wouldnt replace the engine in an 11 year old car anyway . if constantly sinking money into it is your issue , sell your Audi . This will be a worsening problem as you hit 12-15 years unless you can do a lot yourself.
id fix it myself till i got tired , then just get rid of it .
Why not? I have no problem putting 'soft money' into the Audi & I wouldn't consider selling it. Replacing the engine would worsen the problem? I'm infamous for subbing it out, so I won't do anything personally. Own Nothing, Control Everything. Would/ can you kill an Audi?
Old 07-23-2014, 07:28 AM
  #13
SloopJohnB@mac.com's Avatar
Less grief to sell your audi and buy an RS6.
Old 07-23-2014, 08:58 AM
  #14
ORKA64.2's Avatar
Felt. A RS6 is around 20K and has more than likely original everything/ minimal services done. My car has brand new everything w/ 10K in service done to it in totality. I couldn't sell my car for more than 10K. The math doesn't make sense for me, cheque it-
4.2 was= 10K
Things done= 10K
Me= 20K all in
Sold= 10K (Bollocks)
RS6= 20K
Things= 10K
Math= 40K total
Alternate Math
4.2= 10K
Things= 10K
Built RS6 Engine/ isht Installed w/ 6MT= 10K
Math= 30K Spent total
I like the 30K option better, it'll afford me some floor mats and a air freshener after all is said/ done.
Old 07-23-2014, 12:34 PM
  #15
Prospeeder's Avatar
Why would u junk an engine for chain tensioners. Take it to a shop that not a total rip off. Tensioners can be had for 2-300 bucks each, and its like 3 hours a side to do them. Not 3k. your being ripped off.
Old 07-23-2014, 04:09 PM
  #16
ORKA64.2's Avatar
I was told 3K both sides and all other pricing provided/ accepted via this mechanic has been within reason comparatively speaking. But, considering I'm not the pro, I will take your advise and see where it lands me by taking it elsewhere. Regardless, I still dislike the Engine... So I am still considering a swap even if I'm able to not get ripped off on correcting this engine. Thanks for the info Prospeeder, I like it.
Old 07-23-2014, 04:51 PM
  #17
Prospeeder's Avatar
Book time is actually 9.2 hours to do both which is generous lol. if its 90$ an hour, thats 828$ labor. 600$ for tensioners, about 60-80 bucks in gaskets....wheres 3000 dollars in that I have no idea.
Heres just one. Hmmm 150$....i say 300$ because we shops do need to mark things up for profit. But its NOT ok for a shop to buy cheap stuff and charge dealer list which is probably why its so much, as list is like 850 a tensioner. But there are aftermarket ones out there for 150-300 or so. I put a 150$ tensioner on my 1.8T Passat and so far its been working fine. Supply your own parts for much less, and just pay them labor.
http://www.ebay.com/itm/For-Audi-V8-4-2-Engine-Timing-Chain-Tensioner-077109087C-077109087P-Left-Side/231223284059?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D23928%26meid%3D8529165386757083107%26pid%3D100011%26prg%3D10200%26rk%3D5%26rkt%3D10%26sd%3D300865084800
Old 07-23-2014, 05:46 PM
  #18
Not a good idea to supply parts….if they go bad you're out of luck…and are you good enough to tell whether the part is bad or the install was bad/sloppy.
If you're going to have someone else do it, they supply the parts and the warranty.
Old 07-23-2014, 07:12 PM
  #19
Knock yourself out if you can get an RS6 engine installed with a 6MT for 10K.
(Grabs bowl of popcorn and settles back to watch).
Old 07-24-2014, 06:58 AM
  #20
ORKA64.2's Avatar
For Audi V8 4 2 Engine Timing Chain Tensioner 077109087C 077109087P Left Side | eBay
It's $100 an hour and you're correct in assuming he is trying to get me at $850 per tensioner, so theres $2600. The other few hundred? I do not know. But yeah, when I heard 3K, it made made think. Thanks for the due diligence in your post, It's much appreciated.
Quick Reply: Diminishing (Engine) Returns
