Old 07-25-2016, 03:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C5) Brake Guides
Print Wikipost
DIY: ABS Module replacement in Audi A6
Old 11-24-2014, 12:00 AM
  #11
elhajj's Avatar
Default audi a8 same issue
i just bought a new one with part number 4E0 614 517E
And the one that was fitted on the car was 4E0 614 517A
Please i really want to know does it need online programming or only reset with a vacom connection any help will be really appreciated because this car is getting me nothing except headache
Old 11-24-2014, 07:15 AM
  #12
SloopJohnB@mac.com's Avatar
Get the replacement part number from the dealer. There are cross references.
Old 11-26-2014, 11:26 AM
  #13
elhajj's Avatar
Really sorry but what do you mean cross refrences ??
Old 11-26-2014, 12:35 PM
  #14
Just Me's Avatar
Once you have the audi factory part number, many parts suppliers can "cross reference" that to a similar or identical after-market part, often made by the ame company that supplies Audi, but with their part number.
G
Old 05-11-2017, 07:57 PM
  #15
jupiter1982m@gmail.com's Avatar
Default A6 ABS module location HELP :(
HI, does anyone know where abs module is in 2001 A6 4.2? It has bosch 5.0 and esp, so its alone somewhere away from the pump.
Old 05-12-2017, 02:57 AM
  #16
johnkk's Avatar
Mine is under the passenger side front carpet. i.e. not attached to the ABS pump like most of the newer ones.
Old 05-12-2017, 06:11 AM
  #17
yea, looked there, all i have is the TCM under there.
Old 05-13-2017, 10:10 AM
  #18
johnkk's Avatar
Could also be under rear seat. Mine was under rug behind glove box. The Bosch ABS pump 5.3 with part # suffix T has the module in car cannot be fixed. If your ABS pump code does not end in T, the module can be fixed and is on side of pump.
Old 05-13-2017, 01:30 PM
  #19
Pardon my ignorance. Was yours behind the carpet on the incline? I only looked under the foot carpet (parallel to the ground) and behind the glivebox in the dash.
Old 05-14-2017, 04:08 AM
  #20
johnkk's Avatar
It's been a few years, but it was under pass side carpet and I'm pretty sure it was on angle in footwell, definitely not under seat. I have an 01 2.7 stick with esp. It's a metal box about 4x7 inches. On a 4.2 might be under rear seat. I tracked down location using info on Module Masters site. Maybe give them a call. If you can get by Miss Grumpy, someone might know.
Quick Reply: DIY: ABS Module replacement in Audi A6
