Last edit by: IB Advertising
- Audi A6 C5 How to Replace ABS Module<br>Step by step instructions for do-it-yourself repairs.
DIY: ABS Module replacement in Audi A6
#11
audi a8 same issue
i just bought a new one with part number 4E0 614 517E
And the one that was fitted on the car was 4E0 614 517A
Please i really want to know does it need online programming or only reset with a vacom connection any help will be really appreciated because this car is getting me nothing except headache
#12
#14
Once you have the audi factory part number, many parts suppliers can "cross reference" that to a similar or identical after-market part, often made by the ame company that supplies Audi, but with their part number.
G
G
#16
#17
#18
Could also be under rear seat. Mine was under rug behind glove box. The Bosch ABS pump 5.3 with part # suffix T has the module in car cannot be fixed. If your ABS pump code does not end in T, the module can be fixed and is on side of pump.
#19
A6 ABS module location HELP :(
Pardon my ignorance. Was yours behind the carpet on the incline? I only looked under the foot carpet (parallel to the ground) and behind the glivebox in the dash.
#20
It's been a few years, but it was under pass side carpet and I'm pretty sure it was on angle in footwell, definitely not under seat. I have an 01 2.7 stick with esp. It's a metal box about 4x7 inches. On a 4.2 might be under rear seat. I tracked down location using info on Module Masters site. Maybe give them a call. If you can get by Miss Grumpy, someone might know.
