Old 09-06-2016, 03:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C5) Tire Repair and Maintenance
Print Wikipost
Do all A6 variants have same spare tire retaining bolt?
Old 07-22-2004, 12:40 PM
Richard Solomon's Avatar
Default Do all A6 variants have same spare tire retaining bolt?
Lots of good news, a little not-so-good.
Good: Local tire guys vouched for straightness of my <a href="https://forums.audiworld.com/a6/msgs/411791.phtml">repaired</a> S6 Avus rim.
Good: S6 Avus (17"x8") with ContiExtremeContact in 235/45-17 fits beautifully in spare well:
<img src="http://pictureposter.audiworld.com/525/s6_avus_in_sedan_trunk.jpg">
Not so good: the plastic-headed wheel retaining bolt doesn't fit. a) The threaded bolt is a bit too short to reach the well socket. b) Even if it reached, the whole assemblage sticks up so much the trunk "floor" won't close.
Thus my question: do A6s with different wheel combos from the factory get a different retaining bolt? My car came with the non-sport 2.7T 5-spoke 16" (16x7) wheels, and a 4B0-803-899-AG bolt which looks like:
<img src="http://pictureposter.audiworld.com/525/a6_27t_nonsport_sparetireretainingbolt_pn_4b0-803-899-ag.jpg">
Could folks with other wheel combos check and see if they have the same 4B0-803-899-AG part?
TIA!
Old 07-22-2004, 02:16 PM
RSC
RSC's Avatar
Mine looks the same but says - 4B5-803-899
Old 07-22-2004, 02:59 PM
Default What year/model/wheels?
By "the same" do you mean same approximate measurements/proportions?
Thanks! I'm guessing there's no "right" animal, since Audi obviously never put S6 Avus wheels in a trunk wheel well (at least in the US) I keep hoping though....
Old 07-22-2004, 03:08 PM
RSC
RSC's Avatar
Default '00 2.7T 16" twin spoke PSK wheels.
Same meaning similar shape &amp; size. The threaded part is about 3 inches long.
Old 07-22-2004, 05:33 PM
Cool, thanks!
Default Any S6 or 4.2 folks who could check? Anyone with factory 7.5" or 8" wheels?
Thanks a bunch!
Old 07-22-2004, 06:41 PM
MP4.2+6.0's Avatar
Default Similar # on 4.2; DIFFERENT look; try another way?
On a 2000 4.2 with 8 x 17's (both pieplates and 5 spoke) with 35 mm offset and 255/40 tires, mine is also 4B0803899. There is NO letter suffix. Different than the picture, on the knurled side you would grab onto, that's the very end of it--I see one more piece/spacer in your picture. Likewise on the threaded end, mine doesn't have the eight pointed star wheel thing--basically your picture has four principal black plastic parts plus the threaded bolt. Mine has only two plus the bolt.
Different approach--you can disassemble these and change the bolt built into it to the right length. Less than $2 at a hardware or auto store that stocks metric bolts. I've replaced it on a C4 2.8 when I changed wheels.
Old 07-23-2004, 07:31 AM
DLow's Avatar
Default Mine looks a little different - no "spacer wheel" on the bottom.
And I can fit the 17" S4 Avus in, no problem...
From a '00 2.7t w/sport split spoke wheels (originally).
The whole thing snaps apart, and you might be able to get a longer bolt somewhere - it's just a hex-head bolt inside the plastic!
Old 07-23-2004, 07:34 AM
Ok, I'll bite how's the dang thing come apart?
Old 07-23-2004, 11:09 AM
DLow's Avatar
Default Re: Ok, I'll bite how's the dang thing come apart?
On mine, there are two small tabs which are un the underside of the **** - in yours they would be under the black plastic "cheese wheel"...
I'll try to get the p/n on mine...
Quick Reply: Do all A6 variants have same spare tire retaining bolt?
